I have to drive to Sydney tonight so if anyone wants free delivery to Sydney then i will take $2100 for the brakes and free delivery to metro Sydney. Once i get back to Melbourne there wont be any free delivery.
  • Replies 41
Posted Images
If you need to knwo wheel clearances i can send you 1:2 drawings that you can cut out onto paper then cardboard so you can use that as a template in your wheels. Will obviously need access to an A1 pritner though
Me please for the drgs. Did you have any joy with the bracket drawings as I still would need to figure out how to mount them to suit either a 13.5" or a 14" rotor.
I was also going to need some new rims (LMGT-4's - hmm cheap night out). I see you had some 17's, did the calipers clear them in terms of trackwidth ok?
Thanks in advance for your time, Roy.
LOL...people make offer. I accept. Then they come up short with dollars :P Oh well. Bump.
Trying to put car back to std (or at least semi std) so will consider a swap for a set of R33 GTR calipers, provided they are in good condition
Yeh would consider, but would have to be about $500 cash on top and reasonable condition GTR Brembo fronts. If you have a full set of GTR Brembos (front and rear) then the cash adjustment will be less.
Plenty of ppl PMing me getting info and going away to count their pennies, but to date noone has ponied up with the cash...so still for sale
PMs replied to, those that are willing to swap front only calipers, i think its best if you sell them then front the cash for my F50s. If you have a complete front and rear setup then i am interested in a swap and cash adjustment
  • 4 weeks later...
These are excellent calipers for the money. I have these F50 calipers with 355mm 2 piece rotors, and they pull up a GTSt well on the track. They're bigger and better designed than the road brembo calipers that are supplied as stock GTR brakes. Good luck with the sale Troy!
    • haha this shit box doesn't drink coolant, for now       Let me guess, they make heaps of power, use the car for straight line driving and don't care about noise
    • They’re so great that I know of someone pulling one out to go back to a sequential
    • Hello everyone. I've recently started the research into R34 GTR front bits and running into eye watering prices. On the plus site it looks like some places make 'replacement' fender liners for these cars. At eye-watering-but-less than stock prices. I also noticed there's plenty of diffuser options available too. What I would like to know is if my following assumptions are correct. 1) The OEM guard liners are actually only 'half' the liner. They go together with the OEM brake vents which are a separate item which looks to be quite a large 'panel' that is part of the liner. The GTR bumper has bolt holes along the front. I assume the ones in the vent correspond to the ones the OEM liner does not have (circled?)   2) The V-Spec front diffuser supplants the brake ducts in the above item. I am assuming these still work with the guard liners as there's no alternate part that I'm aware of. I don't see how they go together, so I'm making the assumption that they have to, somehow. I know the center splash guard is different on the V-Spec (and is the price of the damn diffuser alone). How does the liner interact with this? 3) There's alternate front diffusers that do away with it all. Annoyingly, a lot of the clones and CF different ones... have no brake ducts on them. I like the idea of them though. My brakes get hot on the track. These alternate diffusers are a lot cheaper than plastic splash guards. I'm assuming you don't have to/aren't supposed to remove guard liners to run a diffuser. I suspect that quite a few people actually do not run the guard liner because with a front undertray you're getting a lot of 'splash' guarding anyway, and most people remove liners given they're probably running a pretty aggressive setup with a diffuser at the front. It would also be nice to know if anyone has ever run the 'reproduction' guard liners and know whether the fitment is OEM quality or "OEM Quality". Example: https://www.ebay.com.au/itm/356254671561 https://carbonetics.net/products/nissan-skyline-r34-gtr-plastic-front-wheel-arch-set Is this knowledge still around?
    • Really, effort is pretty low. You hand fistfuls of cash over to someone else and pick it up when done...   And at least this shitbox isn't drinking coolant right?
    • And most chargers that most DIY people own would put bugger all power back into the battery between cylinders. I've always done it with jumper packs/second battery connected. And that's on any car.   Because race car, and wanting the lightness.  At least in an R33, putting a bigger battery in can at least help shift the weight balance backwards
