Hey guys,
Long story short: I own a R32 GTS4 rb20det moderately to highly modified, about 2-3 months ago i damaged the engine, we think its a head gasket but havent pulled it apart yet. I have been more keen to get my RB25det in! So anyway, when i blew the engine a few months back, we rolled it and stored it at a friends place near by. Last night we were finally able to bring it home!!! so happy to see it again!!!!!!!!!!!!!
ANYWAY, the rb25 hasnt been rebuilt or anything it came straight out of a staggy half cut with low K's so im keen to just throw it in. But there is one precaution i would like to take and that is replace the OEM head gasket with a metal one to help prevent blowing another one too soon. This will be done by me and a friend so just wondering what were the 'technical' aspects about this project... ive heard you have to undo the bolts in a certain sequence to prevent bending the head as it comes off? Anyone know this sequence?
Any extra info would help :blink:
Cheeeeers
https://www.sau.com.au/forums/topic/176583-my-baby-is-home/
cheeers guys! ripped the RB20 out this morning! so now its time to start preping the rb25 for the drop in.
I dont want to push anything over 240rwkw now as i want to keep a bit of reliability/streetability, id be more than happy with the more responsive and torquish power from the 25 after driving the 20. All the parts i have are interchangable between the engines except for: Jun front fed Plenum, custom fuel rail, and GTR injectors. Trying to figure out if i should go stock 25 plenum and pay for extra cooler piping or buy another front fed plenum to fit the 25...
So now its time for my shopping list... Would love for some input. (Trying to keep to a budget and only getting what i NEED for this to work.)
The RB25 shopping list: (So far...)
- Head studs
- 555cc nismo injectors
- Metal head gasket (What size is recommended for say 14-15psi of boost.)
- Gasket kit
- New belts
- New hoses
- Oils and fluids
Edited by zertek
https://www.sau.com.au/forums/topic/176583-my-baby-is-home/#findComment-3230470
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
