hey guys just wondering which one i shud put my money on if my engine blows? :D
i here 1JZ's own rb26dett's in the fact that the jz internals are soo strong with any work done.
let me know your opinions :)
What car is it going in ? S13 ?
How much money you got ?
1JZ is a good engine but i wouldnt say it owns a 26...
https://www.sau.com.au/forums/topic/177014-rb26dett-vs-1jz/#findComment-3235163
For outright performance they don't "own" an RB26DETT, though they definitely don't embarrass themselves - what makes them a particularly good buy is how cheap they are (at least in NZ) compared to an RB26DETT. They are even quite a lot cheaper than RB25DETs, which they in some respects are a bit better than.
https://www.sau.com.au/forums/topic/177014-rb26dett-vs-1jz/#findComment-3235186
fark another HPI puppet.......
both have merits and drawbacks, that said after building the supra i like the 2j better than rb26, but the differerence is only cubic capacity. Im sure if i got to compare a decent rb30/26 i be back on the fence.
https://www.sau.com.au/forums/topic/177014-rb26dett-vs-1jz/#findComment-3235345
I would say if your engine blows don't put in a second hand motor at all. either rebuild the one you've got, or rebuild an RB26 or a 1JZ. putting in a used second hand motor is not always a recipe for long term happiness.
https://www.sau.com.au/forums/topic/177014-rb26dett-vs-1jz/#findComment-3235352
I'd personally take a 1JZ over a 26 if u wanted to modify it. I explored the avenues os 1JZ, 2JZ or RB25DET for my GTS-X. A manual 1JZ halfcut can be had for cheap but then the fabricating to fit it is about 4 times the cost of the 25 for me. Everything on the 1JZ is backwards compared to the 26 as u probably know. For me to buy a good 25DET and gearbox and everything needed to put it in was 3500..... roughly 1500-2000 so max 5500 to have it installed, wired and finished with new seals and timing belt, water pump etc. 1JZ was about 2500 for everything needed including the halfcut to sell what i didnt need to do the swap but in the end I was looking at 8000 minimum coz I'd need a modded exhaust, completely custom engine and gearbox mounts and crossmember etc, completely custom wire the loom, plenum is over the other side etc etc. If u have the cash and if I had the cash I would have gone 2JZ but the 25 for me was more affordable. I guess ur going to need custom gearbox and engine mounts for either engine so look into it. If your going to mod it a 1JZ or 2JZ would be best if you dont want to touch the inside.
Liam
https://www.sau.com.au/forums/topic/177014-rb26dett-vs-1jz/#findComment-3235486
toyota engines are generally stronger, but unmoddified, your unlikely to break either... you start modding, you better keep an eye on the 26... the 1 or 2J though, will be more reliable...
seen it happen all too often...
https://www.sau.com.au/forums/topic/177014-rb26dett-vs-1jz/#findComment-3235698
Go the 1J, just put one in my bro's Cressida, what a weapon, boost is just about instant even with the Auto, i was suitably impressed (well I would be considering I have the no torque RB20 to live with).
That's OK, he will boil the brake and clutch fluid shortly.
:D cheers :D
https://www.sau.com.au/forums/topic/177014-rb26dett-vs-1jz/#findComment-3238245
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
