Hello All,
Just pulled my engine out a few weeks ago and recently placed it back in the car.
While it was out fitted Twin HKS GT2530.
Just wondering what Camshafts would be best for these turbos/setup.
Wanting more Low End than Top.
What degree and lift should be good to get the FULL POTENTIAL out of the turbos?
I've asked someone in Japan and he said TOMEI 260 in and ex with 10.8 High Lift.
What are your thoughts?
Need the best option.
  • Replies 44
Hello All,
How much do you want to rock at the lights....?LOL
What other mods. do you have?
Have you Dumps..full exhaust?
The 9.15 Lift Tomie Poncams is a direct bolt on(Might need some new shims though).
This will also work with a standard computer..if you decide to take yours off for some reason or another.
They have the best low,mid..but not high response.
The higher the lift generally means the Higher power at higher rpm.
I have them on mine...with Garrett 2860-5(Equivalent to 2530's)
Run through the RB26 Turbo Upgrade and you will see power results...bear in mind..I have a street/track tune...
Top end power was not what I was looking for.....
EDITED....Link provided for cams and pulley set...it is cheaper .
http://www.nengun.com/tomei/pon-camshafts-pulley-set
Hey,
Good Input by all.
Hmm Is it bad to rock at the lights :D?
Get people afraid.. but wont be racing :D New Laws Kill.
Forgot to mention.
HKS Dump Pipes, Twin 3" Exhaust (through Cat), HKS F-Con (Not yet installed as still running stock cams)
"The higher the lift generally means the Higher power at higher rpm."
Very interesting. I'm hoping to take it up HIGH RPM. So looking for the best setup.
Am also looking for a street/track tune. No highway racing :D
I got rocking.
Not much..but enough to hide my face when a mum and kids stop next to me.
They might think I am a young turk..when I am a old one...lol.
Poncams....no more needed..if you don't race.
Great rock and great low to mid range......they are good at high RPM to if you have the right engine internals
that allow you to go past 9000RPM.
You can get it to rock like a bull if you like...talk to your tuner.
You will need a tune after the install....you need adjustable cam pulleys if your tuner is to get the maximum out of your set up.....but make sure you tell him were you intend to drive it.
You will need a better fuel pump...larger injectors..555 or above..and regulator if you don't have them already
Good luck.
Yes, will need a tune.
Are there big differences in a street and track tune?
few extra things forgot to mention.
2 x extra fuel pumps + surge tank, *EDIT* 660cc Injectors
Edited by Owgasm
I was running Tomei 260-9.15's with my 2530's and made a good improvement to midrange when I was running them.
I've gone back to standard cams on the 2860-5's however.
Hey Snowman why back to std cams?
I am on stds now and was looking at the 260 9.15 when a few $ spare. Am I wasting my time?
(By the way I am very happy with the way the std cams run at 0.85 bar but not sure with higher boost.)
You need cam gears as a min. They are worth every cent on the RB26 :D
Although the only issue i see, is the HKS F-Con.
You really really limit yourself to a tiny handful of tuners when choosing this particular ECU.
Where as any other ECU on the market just about will be tuneable by any workshop should you have issues with it at any point.
Just something to think about.
you change the cam pulleys in order to be able to tune the cam timing for what you want power curve wise. the Tomei cams installed at 0 make less power than what you can potentially make by adjusting them ,alot less.
rev210, what sort of kw difference do cam gears make, apporximately? Like the original poster I am looking at tomei poncam b's.
thanks.
james.
Edited by heller44
With 2530's my choice would be;
264's
around 9.5mm lift
any brand, I have yet to find a difference
:D cheers :)
would there be much difference between 264 9.5mm cams and the 260 9.15mm poncams in terms of power and response?
Im pretty sure tomei poncams run best at the zero setting after what I remember reading from SK posts. The other tomei cams most likely need some timing adjustments.
Correct me if Im wrong and Ill get our 32 gtr retuned with timing adjustments on the poncams :)
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
