Yeah ive done a little.
Its converted to a 2 seater so the back seats and trims are gone, all boot trims, carpet etc. Still need to remove the sound deadening. Im leaving the headlining in at this stage, mostly because of the sunroof. Also the hicas and ac and stereo is gone, heater is still in place.
Im using a gtr bonnet and seats both get u a few kg's
Edited by Gts30t
Stupid RB25 gearboxes. Thats why i am holding off as long as possible and making do with the 20 box. I read a while ago that PPG were doing a gearset for the RB20 box, so better ratios for a 20 with a big turbz off the thing, quicker gearchanges and less weight...just have to wait for the release and cost :(
I am on my 3rd clutch, and 195,000kms. When i left Sydney i think it was over 3,500kms of track work in the car. Since moving to Melbourne have done a couple of drag nights, plenty of motorkhana work and two Duttons. And all of the Melbourne work has been with between 215-260rwkws. I only use the expensive Castrol blah, blah oil. Syntrax i think it is. They dont take abuse to well, but they take use just fine :(
Screamin'
I believe you are familiar with my B310
But not my Goddy
Ahh, but I am familiar with IIIRII. Good example of comitment there!
My Skyline has now had the performance mods of Nissan stripes added.
New head/induction build is still progressing slowly: http://www.skylinesaustralia.com/forums/Rb...ld-t222993.html
    • That sounds like an excellent idea. But total self-sufficiency means exactly that. You have no-one else to blame when your system faults out and you have no power for a week or two while it gets fixed. You'd have to go the whole hog and get a diesel genny and all the switchover gear, to get you through such times. And, despite the fact that over 20 years, my system has been pretty reliable**, I have seen so many inverter explosions (or less dramatic deaths), panel and roof JB fires, and so on, over that time, to know that the stuff is the same as any other bulk Chinese manufactured stuff. The failure rate is well above zero - both on the equipment and on behalf of the meth addled installation labour force. And then..... warranty and means of redress against the supplier you bought the gear from. Best I can tell is that only a handful of solar companies are still around within 5 years of starting their advertising pitch. They disappear and phoenix like crazy. So, as per 1st paragraph, I suspect the only way to is go balls deep and spend maybe 2-3 times as much as you might think, so that you have every base covered. Plus, know and understand your gear intimately, so you can diagnose problems, sort them out yourself, etc, etc. Plus, probably have to consider upgrading various parts as the years pass, to maintain compatibility with newer stuff, performance and reliability, etc, etc. Whereas, remaining attached to the grid has an ongoing cost that keeps going up even if you use bugger all power from it. But it does provide the fallback in case of the worst case with your own gear. You either pay up front or as you go, I suspect.
    • Add more solar panels to the array. Call the electricity company and tell them you're moving out... Live off grid electric wise
    • Hi Jasmine. How's the war going?
    • I'm extremely suspicious of the VPP stuff. Best I can tell, you surrender any and all control of your panels and battery to the VPP, because there's no way that anyone could write a sufficiently useful set of "rules" as to how much you would be willing to let out of your export meter at any given time. If one of your main interests is to have enough in your battery every evening to get you through the night without having to import, you could easily find yourself with nothing in your battery at the end of the day, or part way through the night, and then be paying import pricing instead of paying nothing. I cannot see how this cannot come to pass.
    • majority aftermarket is an10 yes, but majority of OEM is An12 r35 OEM cooler lines at close to an 12, the hard line that car uses is almost 20mm  Porsche OEM is also AN12   i figure, if our power levels are close to 1000hp, then AN12 should be a must if many OEM standard power vehicles use AN12
