Got some of the R33 stripped on the weekend. just have to take the rear seats out, and the carpets now.
We have the same brakes and air compressors :P
And it looks like my rotors are on the wrong way, thanks for posting that pic up!
the slots don't matter, it's the direction of the vanes that's important. in the pic posted you can just see the curve/angle of the vanes is correct. phunky, yours may have the slots cut the other way in relation to the vanes. (ie with the rotors mounted correctly vane wise your slots may face the other way).
Good to see that everyone has been working hard on thier machines, as have I. I've been working on seting up a set of GTR throttle bodies and plenum on to an RB25. Not a job for the feint hearted. Finaly got a decent tune in to it today. No real power increase but emensly different fuel mapping was need everywhere and took the best part of the day. In the end the power comes on a little earlier in the rev range, has a flatter curve and moved peak power up by nearly 1000rpm in the rev range. Might be easier to power out of corners? will track test and refine tomorrow at morganpark.
Will post up some pics later. Off to do a wheel alignment for gatton street sprints and testing.
Mine are from a GT-R, and are the same brand of rotor, so I think they're on backwards... I knew I'd get it wrong :pirate:
hehe, thats the second time your rotors have been put on the wrong way dane... i did it the first time they went on the gtr, didn't notice until it i'd put everything away and taken the car off the hoist!
This is my baby hopping to have it finished by super lap 2010 but it costs so such.
It has an RB30/26 Motec M800 Alcon's ext and it is all done by Ben at Race Pace Motorsports.
mumma mia! that's a spicy meatball you have there.
any more details? turbo(s)? suspension? it looks very serious, and very nicely done so far. no doubt it will be a weapon as ben certainly knows how to make a quick track GTR. :)
when it's finished I'd be happy to test crash... i mean test drive it for you... :P
Thanks for the thumbs up guys :ermm: .
The Turbo is one of Ben's custom T04Z's on a Race Pace manifold with an HKS 60mm gate.
The suspension will be a set of Bens custom tein's and all links will be Ikeya Formula
I have made an addapter manifold to mount a set of GTR throttle bodies and plenum for my RB25. It has worked quite well but not improved the area of the fine throttle response I was looking for. It has improved and moved the power up higher in revs though.
I'm going back to the old setup.
interesting, i went the rb26 plenum setup on my 25 and i gave alot of response.
Before the setup had full boost (16psi) at 3300rpm
after
Full boost (18psi) at 3000rpm
:sweat:
I'm using the blitz kit
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
