its certainly fun to drive! Mine was used for street/drift in Japan before it came over here. Had 9/7kg springs when I first got it! But in that vid it had the 7s (390lb) in the front and 325lb rears. The rear end still hates any hint of a bump! I've now moved the 325lb/in springs to the front and waiting on the 225lb rears to arrive. Should calm it down alot. But I'm more than slightly sceptical about the rear Tein Drift-Spec shocks as well... also have some rear radius/traction arms to fit, and after those changes I might try some pineapples if it still needs more traction. It will get there eventually. It hasn't even had an alignment yet!
Here's another update with my big little engine project. I spent last weekend installing cams, rocker covers and assembling the intake manifold and throttle body setup. The external oil feed for the head is now connected too.
The picture shows a standard RB26 timing belt on the engine which is too short. Ive sourced a suitable length belt from an audi 80 series that solves that problem. Twin tensioners are used to allow the cams to be positioned properly at 0 degree's. My high octane sump extension is being welded on this week and the pair of GTRS's should arrive fairly soon too with any luck, so not long till its finished now.
That is a mega mint R32 Ben, i sincerely hope mine looks half as tough
should have kept your weds then you homo. I still have mine. :D :D and they are the super duper 17X9 +18 ones. :)
I will give you 60k for it. Thats the going rate for a pedigree R32 these days isnt it? Yeh, the Weds are lighter then the homo TE37s i have got now....stupid me. I may have to grab back my 17x9 Weds and accept that i will only get to run 235s and not the 255s i hoped to run in the 9.5" TE37s.
I knew you'd pick that Harry. LOL
To be honest, I just can't keep it flat, it needs a little lift to get some transfer onto the front, otherwise big understeer = hello grass maybe wall. lol
I'd imagine though, if I did grow some man-balls, I'd be even faster than you than I already am around there :D lol (just playin mate :D)
Edited by Marlin
Nice looking engina :)
Flame captured on film..... might be due for a new cat convertor you think? :D
lovin the flame pic!
yet to get a pic of mine doing that... when it shoots a fireball at night it lights up the whole cabin... yes I have the maturity of a 5 year old :D
good looking car ben. i miss all the damage thoe. its just to straight.
oh and dont show any cage builders that pic because your A pillar bar is all wrong. :D i jokes with you.
I'd imagine though, if I did grow some man-balls, I'd be even faster than you than I already am around there :D lol (just playin mate :))
I was kinda asking for that... Just enjoy it while it lasts mate! hehe
    • Did you pay with a credit card? I'd be putting a charge back through then finding a new sparky to sort it out.
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
