Why does the speedometer on my skyline r34 25gt 4-door non-turbo only go up to 180km/h - makes it look kinda foolish seeing as my 1993 camry executive (nowhere near as powerful) had a speedo that went up to 220.
Is there a way to get a speedo that goes up to like 280/300/320 installed... (even tho there is a speed limiter at around 190)
https://www.sau.com.au/forums/topic/177287-speedo-wtf/
lol eug, its that simple? how much u reckon it would cost me to get it installed by a pro and all?? and lol i dont really wanna get an aftermarket ecu to get rid of the speed cut. i want it to just look good lol, a 320km/h gauge would look awesome hahaha. so yeh my questoin again... how much would it cost me for a nismo 320km/h gauge + installation
EDIT: and has anyone done this?
Edited by CDA
https://www.sau.com.au/forums/topic/177287-speedo-wtf/#findComment-3238930
you can get a wide range of products to enable 180km/h+ with out replacing the ecu, also you can get replacemet dials that go to 300-320, they start at about $100 and go up to about $800. plenty of info around just do a search.
i put 300km/h gauges in my 33, got them off the forum from AMEC for around $130 and installed them myself in an hour, too easy.
https://www.sau.com.au/forums/topic/177287-speedo-wtf/#findComment-3238983
they are selling them on ebay to fit a gtt (performance wise) located it N.SW for $600,
i could think of alot better thing to spend $600 on though all you have to do is take the original cluster out an put the new one in/its that easy
Edited by SMOKE'M
https://www.sau.com.au/forums/topic/177287-speedo-wtf/#findComment-3240717
how is a 4 door 34 considered rare? Non-turbo 4 doors are everywhere.
Your car is never going to see over 180km's so why bother wasting money on a mod to look cool? I suppose if your mentality towards your car is like that than i would also suggest installing a boost guage aswell :rolleyes:
On a more serious note, by the time you pay $100-$600 to get some guage replacements and then pay someone to put them in for you since you dont want to do it yourself (more $$$ for labour) you would have been better off saving some cash for a nice kit to make your car look nice.. Also i have seen people puts those aftermarket dials in and the speedo just ends up reading up shit creek and the el cheapo ones dont always fit as well as the seller tells you!
End of the day. Your choice man but by the response on here should hint what a waste it would be. Ch
https://www.sau.com.au/forums/topic/177287-speedo-wtf/#findComment-3251447
Completely agree with this ..
then when someone in the know ( ie knows skylines back to front ) sees your 300 Km/Hr speedo you better be prepared to get your seats cleaned whilst they p1ss themselves laughing at you.
sorry to sound harsh mate.. but as pointed out early , I am sure there are better places to spend your money rather that making your car appear something its not ( ie capable of 300 km / hr )
dont take it personal its just my opinion ok?
https://www.sau.com.au/forums/topic/177287-speedo-wtf/#findComment-3251735
    • If the gases flowing in those two tracts had the same properties, you could maybe use such broscience. But the exhaust has a different composition, different normal density, different actual density (because of different normal density, and mostly because of the massively higher temperature), and different viscosity (again because of much higher temperature). Consequently, all of the fluid dynamics parameters that matter, that you calculate from these inputs, such as the Reynolds number, friction factors (for wall friction) and so on, are all incomparable.
    • And we shall have to presume that Canada is the same?
    • In the US almost everything is E10. It can't exceed 10% by much or fuel systems have trouble adapting. At the same time because MTBE, MMT, and TEL are all banned they need as much ethanol in it as possible to boost octane.
    • I was mostly jesting. In my experience (and probably only my experience) the R34 GTT physical airbox space is actually too small to flow the amount of power it wanted. By sealing the box, I made it so it could only be fed by the ducts themselves. So you can seal it up and get nice cold air which IS good, but at a certain crossover point: More Hot Air > Less Cold Air I don't think you're at this point. In my case merely ducting the hot air intake with a very focused set of ducts counteracts the fact it's in a V8 engine bay. More cold air obviously best. The solution looks great.
    • Nah, the OEM CAI pipe is still installed behind the bumper, it is about 5" x 3" oval at the engine side, tapering down to a 3" pipe behind the bumper where it gets all the ambient air it needs Engine side of radiator support OEM intake pipe "oval hole" that is right in front of the filter My OEM NC1 CAI pipe: From NC2 onwards, below pic, they come slightly smaller at 2.75" diameter with corrugations and a resonance chamber to reduce intake noise, lucky for me my NC1 has the bigger noisy one, LOL   Basically, the "sealed" airbox will just get ambient air from a 3" pre filter intake tube that is the same size, 3" as the rest of the intake pipe post filter, and if a 3" intake isn't big enough to flow enough air for 150 killerwasps then there are other issues The whole intake is basically the same length as OEM, but it is now about 30% bigger from the airbox back through to the new intake plenum than OEM, and the intake plenum is port matched to the head And the intake is now about 30% bigger than my 2.5" exhaust, so the suck, squeeze, bang and blow black magic should be fine, well, to my uneducated understanding of fluid dynamics anyway Talking the the guys at MX5 Mania, it may even make a few more killerwasps as the intake isn't sucking hot air, especially off idle or when in slow traffic when it would be sucking hot air  As for the difference in IAT, I haven't logged IAT yet, as I don't currently have a OBD2 reader, but I will have a play with my thermal lazer thingie next time I take the car out to sèe how hot stuff gets under the bonnet near the intake filter prior to installing the air box, my "assumption is it has to be much better after the air box is in and sealed up compared to what it is now The aftermarket "performance" CAI elephant in the room: Aftermarket CAI intakes typically have the air filter tucked up behind the bumper, with a 2.5" intake tube (the OEM intake pipe is actually about 30% bigger than the fancy pants "aftermarket" version.....WTF), and you need to remove the bumper to service the filter, which is a PITA Like dis:
