I use motul 8100. Always been good and never have a problem with it. Synthetic and not overly expensive.
I think i used drift filters ages and ages ago but havent been able to find them since so just went ryco but again no problems there either
  • 3 months later...
  • Replies 154
Is it ok to run on Castrol Magnetec 10/40W & Ryco filters on R33 GTST?
Never seen a track or drag strip.. only used for normal daily drive.
How often do I drop the oil & change filter?
Can someone please advice.. thanks
Personally I prefer Fuchs 10w30 (you will find it at bursons) and I use Ryco or genuine filters.
You could run 10w40 if your car is ~150k km+ or sees track time.
daily driven and not thrashed change at 10k km, otherwise 5k km. If you do more long drives than short you can do the longer interval, if all short drives the shorter is better.
I change at 5k km as cheap insurance.
  • 3 weeks later...
has anyone used the Nismo Verspeed 5w40 ? I have been using 300v all this time but over in this country its harder to get Motul... and I won 5 litres of Nismo at the drag racing comp here.
i am a bit worried to change the oil because 300v has been really good for me so far
the nismo stuff is good too. i've used it in japan. as you know I also have a big love of the 300V but the veruspeed stuff will be fine. hell it may even be some kind of motul re-branded.... there is a very close association between nismo and motul.....
Yeah I will give it a go, its expensive oil the Nismo stuff... will see how it goes. I will go back to Motul next year as I wont be buying Nismo
  • 3 weeks later...
you are right. confirmed that the Nismo oil is Motul!!
Can you get Mobil 1 Synthetic oils Guilt ?
Sounds silly but when Porsche specify Mobil 1 Racing 4T 15W50 , which is bike oil , it cant be too bad . Aprilia and Triumph like it for sport bike apps as well .
A sport bike with the piss bags being flogged out of it is supposed to work its oil prety hard - high revs and big temp variations in their engines .
Since bikes tend to have the crutch in their oil , and a gearset as well , it can't have the friction modifiers like road car oil has . Has to stand on its own feet without being pasterised and homogonised so to speak .
Racing 4T synthetic also comes in 10W40 and 20W50 - second one for Harley earth moving equipment ...
A mate of mine works for a competition quad bike mob and I pay $16.20/L out of their 44 gal drum .
When you coming home and buying a "Tunemobile" van ? Maybe a table top with a dyno in the bed ?
Cheers A .
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
