easter 2006, you over filled your trans fluid, remember when the offical pulled you and me out of the line. you had a big pool of fluid under your car in the stagging lanes and your crew guy at the time said oops, over filled the transmission.
Nah its not ringing any bells but my memory is pretty crap lately.
Adrian are you putting slick on now or sticking with the radials?
  • Replies 843
Posted Images
i looked at taking the power steering off to save weight but honeslty after driving through lee's trans fluid a couple of easters ago and getting very sideways at half track, i wouldnt have like dto try and keep it off the walls without the power steering.
just find another 20hp to compensate
No danger of losing the power steering - Stuart is just a very angry man when he gets in a weight reduction type of mood. :D
Lee, radials for Sport Compact and some little slicks for the rest of the time. Slicks aren't a priority for me at the moment though.
Does weight do that much of a difference? Should I be ripping out the original fuel tank and other little things in the hopes of getting the car lighter?
I keep trying to start a diet to lose 20kgs from the drivers seat but probably easier to get it from the car...
I'll be cheering for you to take over in SRWD to give shane a run for his money... :(
I'll be cheering for you to take over in SRWD to give shane a run for his money... :D
Weight makes a massive difference but remember that in some classes, as with SRWD, we have minimum weights to meet. Shane and I don't have that problem because we drive tanks that only have to go 3250lbs (3100 + 150 penalty for non-OEM box) which they seem to do easy enough.
I'll just be happy to be back out there racing again and hopefully a little closer to the pointy end of the qualifying order than my normal 4th - 8th position.
the weight penalty for the trans is only in the ANDRA book, not in rays. when they merge next year there will be no weight penalty for the trans. that comes from both the box and sharpies mouth. :D
Well you just made my f**kin' day! 3120lbs here I come! Stuie, get the spanners out! :(
I'll be cheering for you to take over in SRWD to give shane a run for his money... :banana:
aly fuel tanks ftw :bunny:
Dont worry, allready had the hole saw out. your going to have to put weight back in by the time im finished... :banana:
Well you just made my f**kin' day! 3120lbs here I come! Stuie, get the spanners out! :bunny:
Stu is just sticking to his name.........doesn't want to lose the Bezerkly identity.
He's also making you a nice free flowing exhaust for the big arse turbo - he's taking a screwdriver to it!
That's okay. I don't delude myself that it's much of a street car any more. Sure it's registered but it doesn't see the street very much. The exhaust can be as screw-drivered as Stu wants :bunny:
I heard from a liitle birdie that yhe machine work will be started on your engine this week.
How terrible do nitrided crankshafts look? Like it's been sprayed with pressure pack primer....poorly!
Looks pretty big....what is it 8L?
You could give me the whole engine....that would save you 200kgs at least >_< I mean only if you really wanna save some weight. :P
8.5L. 200kg you reckon? It'd be fairly quick then!!
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
