Hey guys anyone used or know of the IHI turbos.. apparently its fairly large in japan and North america.
got this turbo its a
IHI Serial No = RHF 149099F
Spec = VN14 0001
11411RP801
i should post this in the forced induction section... oh well..
ive been told its a Ball bearing very similar to the 2530 by garret/hks anyone confirm..
i got a pic somewhere.
thanks
mark.
https://www.sau.com.au/forums/topic/177493-about-a-ihi-turbo/
The RHF series are ball bearing according to this site. Also, according to this site, the VN14 spec is an RHF5B turbo which, according to the chart in the first link and depending on exact spec, is rated for 73-208 ps. This is pretty much all the info I could find on this particular turbo, your best bet might be to use the contact info in the first link to contact IHI in the US and ask them the same questions you've posted here. Don't forget to let us know how you go :yes:
IHI are quite popular in the Subaru scene I believe, with most STI's being factory-fitted with an IHI turbo of some description (can't remember spec), and IIRC VF23's are a popular swap for WRX's. I had an RHE62 I was going to bolt to an old Commodore before I came to my senses :banana:
The RHF series are ball bearing according to this site. Also, according to this site, the VN14 spec is an RHF5B turbo which, according to the chart in the first link and depending on exact spec, is rated for 73-208 ps. This is pretty much all the info I could find on this particular turbo, your best bet might be to use the contact info in the first link to contact IHI in the US and ask them the same questions you've posted here. Don't forget to let us know how you go :)
IHI are quite popular in the Subaru scene I believe, with most STI's being factory-fitted with an IHI turbo of some description (can't remember spec), and IIRC VF23's are a popular swap for WRX's. I had an RHE62 I was going to bolt to an old Commodore before I came to my senses :D
208ps only.. ther goes my plans.. lol..
um its a whole kit im buying off my mates mate. just doing research.. basically that pic i sent all that for 1500 Z32 afm, apexi intake, 550cc squirters, mani, dump and turbo.
i have sent an email to ihi the actual company.. and 5 others to representatives over the USA.. ill let you know how i go.
looking at the pics its similar to a 28
yeah subarus use a VF series by IHI i believe
Why not just get a Garrett or HKS setup, proven a million times over.
One can only assume your cheap? Like Subaru drivers :)
ahaha yes.. not really cheap just got offered a kit.. came off a S14 in japan. imported the whole thing...
was gonna use a 2871R probably still will..
subarus are cool and u love them col..
208ps is based on my possibly wrong interpretation of the very limited info I could find, it's quite likely that the turbo you're looking at will support a lot more than that. I'm keen to hear what IHI themselves come back with :D
One can only assume your cheap? Like Subaru drivers :yes:
so how come u used a chinese copy for ur manifold and wastegate then col?
farken hypocrite :ninja:
its not a question of how well it works, its a question of how long it's gonig to last
maybe thats why ur selling ur car? :)
It will last, but 4 cars and a bike for 2 people does not make sence.
As the skyline gets the least love its going.
Trust me. He aint sellin his car. :P
Its sold pending payment actually. Im just not holding my breath as the buyer is 18 and I dont think he will get th loan from the bank.
Apexi turbo's are based on IHI turbo's
thanks for that. something i didnt know. ive heard good things about the apexi turbos.. so i think i might just look it over and pop it on the SR and see what i run up.
im still waiting for a reply from ihi... hurry up yo.
  • 1 month later...
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
