I bought a certain viper with SST 2 Mile range and Ill have a kill switch in the f**ker too. so if they start my car which is les than a mile away ill play with their head with the controller before i clock them in the back of the head 2 minutes later when i sneak up behind them.
  • Replies 63
LIES
1) viper doesnt have 2 mile coverage
2) you cant setup a kill swith to work from the remote
3) you never planned a cruise
why will we ever belive you again :P
and yes you CAN set up a kill switch with the viper, who said anything about a remote?
3, i have a route for a cruise, NO I will not plan it yet and i have f**king stated this so please f**k off about it thanks.
Sorry 1 Mile. I meant 2 km.
ok your forgiven
Not forgoton
this is what gave me the impression your gunna let them start it hear have your remote beep you and turn the car off and sneak'o them
probably not allowed, SAU on the other hand.....
BS. I saw on today tonight they did the exact same thing. Leave possession in plain view in car. Thieves break in to steal it. Cops on their ass.
Then again, it was today tonight.
Today tonight yes, but it wont hold in court. Unlike america entrapment is against the law here go figure....
We don't have entrapment laws & entrapment isn't a defence in Aust so, legit police stings are legal & should hold in court.
Not very smart posting here what sort of alarm you have on your car mate :laugh:
you clearly dont know pauly :laugh:
i thought viper arnt blackwired so there for insurance companys wont allow it?
depends on insurance company mine which is Famous say any good alarm with 3 point immobilizer and self arming
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
