  • Replies 159
Yeah i remember seeing this when you first got it after your other line.
when you used to come into the newsagency in jimboomba. :P
Ahh my Lotto stops :rolleyes: Yeah Calamvale is my new haunt, finally left Jimboomba after 15 years :huh:
Ahh my Lotto stops :thumbsup: Yeah Calamvale is my new haunt, finally left Jimboomba after 15 years :)
bahah i used to work there.
yeah jimboomba is nice...but too far out of the way.
went to the spit last week with a mate + good camera :( and took a few shots.. and this one seems to turn heads
enjoy :P
p.s Llynden ill be getting that new door put on this week :happy: wo0t! shes will be all smick again 8===D YAY!
Edited by 32JEZ
I don't really have any decent pictures of my car on it's own.
This is my favourite picture of it though, kudos to anybody who can recognise their car in the shot:
I dont recognise any cars, But I recognise that guy in the white shirt .. lol @ arman.
