pfft 80%
where the bloody hell is a murches cd changer?! James, get a murch, we need to know these important things!
70% is bloody good if you havnt driven these cars?! how else would you know that you have to be stationary in a 430 to make the roof work or that the paddels are attached to the wheel in an r8...?
Make our own quiz: how many little buggery bolts hold the roof onto an exige?
I can help with that. :rolleyes:
---> http://aussieexotics.com/videos/lamborghin...irst-gear-14872
How about if you ever get asked what's under the ashtray of a Gallardo?
---> http://aussieexotics.com/videos/lamborghin...i-ashtray-18881
That looks like the Lambo we resprayed when i was working at the panelshop
was originally red and resprayed it to black
man- even the real ones look like kit cars these days :P
I know it's a cliche but these things are so much more dramatic in person, it's impossible to not be impressed. Photos = zero-justice.
In motion they are sublime to watch, here's a vid of a Lambo club run we went on last year, not hugely exciting to watch (the "exciting" stuff doesn't go online :) ) but it's still great to see and hear all of them in motion rather than static.
---> http://aussieexotics.com/videos/lamborghini-club-run-7188
The gallery from the day is here:
---> http://aussieexotics.com/drivers/thumbnails-185.html
AussieExotics.com - Click here for hi-res
White 997 GT3RS last night on st kilda rd, pulled up next to me as I was waiting for a tram.... had a quick chat with the owner, then the lights went green...he took off and i had half a woody from listening to the sound of it at full throttle....mmm i want one
The Gran Turismo is such a gorgeous car!
Our new prancing horse arrived today. Miami Vice special in black/white.
Is a 2007 update F430 F1 - so a bit different from the red car. Dash treatment is all carbon fibre and pretty sure it comes with a Cafe Sienna parking permit!
That is one very very hot Fezza you have there James. Sounded ace too, not as cool as the Stradale but ace none the less.
Dash pics?
Just ran into a mate in his F430 spider... had it for about two years and only put on 5k, loves his GT3 too much.
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
    • street use or race track, what hose size and why? what factors change with the hose size options ?   see most comon is an10. when you see most oem external coolers are closer to an12? does high volume oil pump like nitto need an12 or 10 be just fine
