Whoa, where did you see this? I've seen the ACT Number 1 (also on a Merc) but not the Vic one.
Damn, plates are worth more than the car.
That plate might be worth over a million dollars... http://www.caradvice.com.au/6764/number-pl...orth-1-million/
why? i'm sure he has worked hard for it...
May have. may not have. I'm sure Paris hilton has worked hard to not have to work a day in her life either :thumbsup: That's not the point though. Why spend that much on a licence plate of all things?
Could buy a nice house for that price.
a nice house AND that car.
May have. may not have. I'm sure Paris hilton has worked hard to not have to work a day in her life either :D That's not the point though. Why spend that much on a licence plate of all things?
Dude seriously, I'm sure the owner of that plate spent that much money on that plate because he has lots of money to spend.
If you think he's only worth the amount of the license plate and that car you'd probably be mistaken.
To clarify i was pointing out it seems like a waste of money to me.
I wish i was in that position, because you know that if he/she's spent that much on a number plate, he/she's crossed a lot of things off their 'things to do with my money' list to get down to 'buy an expensive numberplate'.
plus, it's probably the only truly unique thing in the auto industry these days. There always a chance that someone else will pull up next to you in an identical murcielago/reventon/Aston DBS but no-one will EVER pull up next to you with the #1 numberplate.
you know what i mean, the odds of someone with a single digit plate being nearby are astronomical (that being said, i followed "27" down the monash a few weeks back) - if you decide to go for a personalised plate the individuality isn't nessecarily there is "SKYLIN", "SKYLNE", "SKYLN3", "SKYLYNE", "SKILYNE" , "SK1LYNE" and the infinite number of permutations mean you 'individual' plate isn't as individual as you might think. Whereas, single digits, well, there's only nine of them.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
