Saw a grey Ferrari California in Church Street Brighton yesterday. was parked outside one of those ridiculously overpriced coffee shops, and was driven by quite an attractive blonde.
also spotted an F430 on dendy street
  • 10 months later...
  • 4 weeks later...
