hi, my r32 is very sloppy in the rear.... like my mates mum hahaha.... anyway... if i am driving straight and do a few quick left rights it seems as if the back takes a long time to catch up...
when i first bought the car the HICAS light was coming on.... my understanding is that HICAS is the 4 wheel steering mechanism... is that right??? ( if not can someone please explain what hicas is?) so my line of thinking is that the 4ws is unhooked. if this is so do i have to pin the back wheels in place somehow to help them drive straight or what???
as you can tell i am a newb and a bit confused by this sh*t....
another question.... are the R32 GTS-4's meant to be 4WD??? mine is not....
Yes.. a 4 wheel steer system that turns the rear wheels by something like 1 degree (or something of the sort.. please correct if not accurate) to assist in cornering
you can get a HICAS lock bar off e-bay for like $150 and lock the back up as HICAS dosnt really do too much and you can rip out some of the HICAS gear and save weight
Why do you think not?
Do you have a dront diff?
Front drive shaft?
Transfer box?
If you dont know what or how to find these things.. just drop the clutch and see if the tyres light up or just pulls :D
or you could do it the boring way and see if you have a torque guage on ur instrument cluster..
and yes.. GTS4's are AWD.. not constant like the EVO or WRX.. but as soon as the rear wheels loose traction (the system cheks this 10 times a sec in the R32 and 1000 times in the 33, 34 and staggy), the front wheels begin to pull aswell (hence making it a 4wd).. once rear wheel traction is re-gained.. torque goes back to only the rear wheels.
hope that helps
*I do not advise doing this on a public road*
Edited by GTS4WD
if i drop the clutch only the back wheels light up... i will get underneath and check for the front diff etc tomorrow... so do you think the sloppy backend would be the hicas??? sounds like it right??
yet another question.... when i had a wheel alignment recently the guy told me the castor was way out.... (this is like camber but different axis correct???)... he aligned the wheels so the tyres would wear evenly however the car pulls to the left a lot.... he said something under there was bent and would maybe cost a bit to fix.... anyone know what might be bent and whether there are castor kits or something like it available....??
The wheel aligner should have been able to tell you what was bent if anything.
Castor is where the wheel sits in relation to the top of suspension. Postive castor (which almost all cars have) would have the front wheels sitting in front of this point.
"if i drop the clutch only the back wheels light up... i will get underneath and check for the front diff etc tomorrow... so do you think the sloppy backend would be the hicas??? sounds like it right??" - does the 4wd light come on when you start the car up? it should flick on for about 5 seconds, then go away when you start the ignition
if it stays on, check your fuses, if it goes off, the 4wd system sounds like it's working properly, check the ATTESSA fluid tank in the boot, right hand side under the cover, opposite of the jack
most 4wd skylines do actually light the wheels up on hard launches, you should have a torque meter on the left side of the dash, watch it, it should rise to round 30-50 when the back wheels are spinning, because it'll start spinning the fronts.
If it doesn't, it means your 4wd isn't workin the way it should, check your front diff and front driveshaft are attached properly.
And your definitely sure it's a GTS4? if it doesn't have the torque gauge in dash and has a boost gauge in it's place, sounds like it's either got a GTS-t dash or is a GTS-t
It's not a GTS 4-door is it?
You don't need to jack the car. You should be able to see a drive shaft and the front diff housing (under the starter motor) by peering in the engine bay.
This always happens when you have had incorrect alignment for a while, it has worn the tyres and now everything is straight the tyres are still worn wrong so it 'tread steers'. Depending on how bad it is it might never get better until you get new tyres or it might wear even.
Oh I like your avatar pic too.
yeah they are actually brand new tyres... got them aligned when i got them put on....
Is it a GTS-4... I thought it was... a GTS with 4 doors right??? or is there more to it than that...???
A GTS-4 has AWD, just like a GT-R. There should be drive shafts to the front wheels. Otherwise, you simply have a 4-door. And of course you will light up the arse end if you don't have the AWD system.
HI INTELLEGENCE CONTROL ACTIVE STEERING
I PREFER U TO CHECK THIS SITE OUT
ITLL HELP U UNDERSTAND A BIT MORE...CHEERS
http://www.solve-it.org/skyline/Hicas.doc
oh, i can see where people get it wrong
sounds like just a GTS with 4-doors
they are known as GTS Sedans :(
they GTS Coupes are 2-door
then there are the GTS4s which are 4wd turbo, or non turbo for R33
don't worry about the 4wd, you don't have it, as for the hicas, you could do what that document says above, but the guy writes all his messages in CAPS so don't trust him :)
Also the kit he has on his site basically doesn't lose any weight from the system, it keeps it all there.
It'll be the hicas causing it to feel funny, i describe it like turning a corner with a deskchair? because it feels so strange
Just get a lock bar from here:
http://www.skylinesaustralia.com/forums/in...l=hicas+removal
and follow this:
remove all lines and front solanoid
http://www.skylinesaustralia.com/forums/in...p;#entry2100796
As for the wheel imbalance, it happens on most skylines, it might just be a bent castor rod or something, find out what's bent, go to the wreckers get a non-bent one, it shouldn't be much at all
then take it to get balanced and it should be close enough to straight
... or, it could be that the rear shocks are stuffed and the thing wallows about like a pregnant hippo.. like mine has the misfortune to do at the moment. :D
haha... wallow it does... but the shocks are definately good...
it's all good dude, your learning :D i used to know nothing when i first bought mine
didn't even know what a turbo was, i had just turned 18, thought i had a GTS, hit the gas, though man this is slow, turbo kicked in, ripped me to the seat, 3 skylines later, about to buy my 4th
f*ck i want a turbo....
  • 4 weeks later...
Here's what i'd do;
1. Check rear tyre pressure ;-)
2. Check the alignment - can make a huge difference. Aligner should comment if the tie rod ends are stuffed, but ask the question anyway
3. Check the bushes - cradle and control arm
If all that's ok it shouldnt be too bad. Then look at;
- hicas lock bar
- subframe (cradle) alignment bushes - aka pineapples
- stiffer sway bars
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
