Hey guys i have the chance to get a link ECU pretty cheap
What i need to know is:
Is it a good ECU?
Who tunes them in sydney?
What are the costs involved in tuning them in sydney?
I need to know whether to hang on to my safc II or sell it and buy the link.
What do you guys think?
Thanks
Mike
horrible, you'll hate it....now what model Link ecu, how much and where? (im thinking of updating my Link ECU) :huh:
seriously, i think it is as good as the guy doing the tuning.
the scope of support for Link's is limited here in Brisvegas, MRT would be one starting point in sydney as they sell the Links.....
Hi mate, my car has a Link ECU & is currently at CRD Croydon being tuned & a few other things done, also i had it tuned at SAS Silverwater Automotive Services earlier this year..
I havnt had any problems with this ecu & its been in use for 3years now, this ecu also doesnt run a airflow meter its just not that popular...
Hope that helps..
thanks guys i will make a few phone calls tommorrow and see roughly how much it will cost me to tune........it has already been tuned on an r33 but with a whole bunch more mods than my one. don't know if that will aid my cause at all
another thing.....i heard that with the link you need to advance the CAS all the way.....this doesn't seem right to me......any input?
lol phrase........if i change my mind i will let you know first........
Cheers
Im running a link.
really good ecu's they use no afm, easy to tune, good cold starts on them starts like factory ecu...i dont really get the best fuel economy though around town driving bout 200kms to $50 fuel..making around 210rwkw..personally i wouldnt touch a pfc i think link are better anyway.
you wouldnt touch a pfc?? you dont like fuel economy by the sounds of things :sleep:
Im running a link.
yeah i wouldnt touch a pfc, i had one b4 the link and sold it, same car similiar mods but smaller turbo and same tuner he gets 180km to a tank of ultimate,could be the tuner he normally tunes safe and doesnt care about power figures to make customer happy but makes sure it will last...but yeah
  • 1 month later...
Ok so i bought the link. installed it and road tuned it using a wideband.......must say i am really impressed with the ease of tuning. the only thing it lacks is tuning zones.....there just aren't enough of em..
But seriously now the power FC is discontinued it wouldn't be a bad option to look into in my opinion anyway.
    • 100% the factory sender is tapered, that is how it seals (well, that and teflon paste or tape)
    • Thanks folks - I've saved a few links and I'll have to think of potential cable/adapters/buying fittings. First step will be seeing if I can turn the curren abortion of a port into something usable, then get all BSPT'y on it. I did attempt to look at the OEM sender male end to see if it IS tapered because as mentioned you should be able to tell by looking at it... well, I don't know if I can. If I had to guess it looks like *maybe* 0.25 of a mm skinnier at the bottom of the thread compared to where the thread starts. So if it is tapered it's pretty slight - Or all the examples of BSPT vs BSPP are exaggerated for effect in their taper size.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
