  • Replies 100
yes i remember ya's just seeing which of you guys are on here too.. somehow i dont think you'll be seeing me on that other piece of shit forum ever again.. over there pathetic crap be sure to keep me updated on next few things happening chris and joe
sweet as wazz....
generally most of the updates are on sauqld.com as things tend to get lost on here and no-one from up here EVER checks the events section.
Catch up with you soon mate :)
  • 2 years later...
  • 3 weeks later...
  • 1 month later...
There are 2 GTR's down here in innisfail a r32 which is adam with a full built motor with a T8834D and ppg gear-box and my r33 with 2860's on it. both are still always getting worked on as there is always things to find to make the car better.
cheers
  • 1 year later...
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
