Well I just picked my car up from RE the other day after a tune and I am extremely impressed with the results and thought I'd share them with my fellow SAUers, aswell as get any thoughts or comments. A big thanks goes out to Ray, I'm sure his more than sick of hearing my voice now. I can't reccomend him highly enough, I'm over the moon with the result, everybody who rides in my car can't believe how responsive it is for a 280 rwkw car. Now to build a new motor so I can ram more boost down it's throat without worrying about melting it.
Mods are:
Apexi PowerFC
HKS 3037 (.68 exhaust housing)
Trust highmount manifold
HKS 50mm external gate
Deatchwerks 550cc injectors
Bosch 040
3 inch straight through exhaust
Hybrid FMIC
Q45 AFM
Splitfire coils
https://www.sau.com.au/forums/topic/179306-recent-tune-results/
  • Replies 41
Posted Images
Cant complain with those results man, nice work.
You must be over the moon as I could imagine, must be sweet to drive especially with that power curve!
Is it just a stock RB25 internally?
Thanks,
Abu
Edited by abu
Yeah mate I'm rediculously happy with the outcome, I was thinking more like mid 260 rwkw region, which is around what it makes on low boost! It's an absolute DREAM on the street (well as much of a dream as that power can be). As for the engine, yeah its bog stock internally but I'm looking to get one built in the near future not so much for power, but more for piece of mind as i dont want to go melting an engine.
Edited by ardie
Thats awesome man, for bog stock motor. 279rwkw is massive.
Must have some serious traction issues now lol
Looking at getting CAM's or anything for it at all?
How much boost did it take to get to 279rwkw?
Thanks,
Abu
Edited by abu
Yeah its a handfull on the road, at full noise 1st and a fair bit of 2nd gear are useless when hard shifting. It's made the car soo easy to slide now, on the straight, just clutch and then throw it a little and then balance the car with the throttle, my mate in his 2535 powered 33 cant keep up with me when we do slalems now, REVENGE!!!
As for the CAMS, I'm looking into purchasing a built motor off a guy on here, it comes with stage 1 HKS cams. Otherwise I'm going the build my own.
That power was made on only 16 psi, but it drops 1 psi over the graph as the boost controller wasnt fully worked out, but I've since sorted that, so theoretically it should have actually made a smidgen more power.
Although its a drift car, it still can make for some quick runs on the streets, I dispatched a worked V8 torana today on the way home from work, only 2 have the guy say how awesome the gate sounded, AN ENGINE NOTE COMPLIMENT FROM A V8 OWNER!!!! WTF!?!??!
nice curve, good ramp, nice average power
you boost build is ideal at 3300rpm where it ramps to 15psi aggressively (how is traction?)
km/h - 3037 - stock turbo
65 - 40rwkw - 60rwkw
75 - 60rwkw - 90rwkw
90 - 85rwkw - 110rwkw
100 - 150rwkw - 120rwkw
110 - 189rwkw - 135rwkw
120 - 196rwkw - 165rwkw
130 - 225rwkw - 170rwkw
140 - 235rwkw - 180rwkw
160 - 270rwkw - 182rwkw
questions;
have you got any pics of the manifold?
have you got any pics of the turbo flange?
what a/r is the compressor?
got a pic of the compressor snout?
i had my r33 series 2 to 233kw at the wheels, and i couldnt launch in that car... i would be spinning my 265's all the way untill 3rd gear if i wanted to. So to have even more i can just imagine....
Seriously though if the engine is stock.... i dont want to jinx you but having that much power on a stock motor is like you caring 800kgs on your back everyday...
But other than that congrats dude
Hey Paul, thanks for that comparison, its nice to actually have a solid evidence of my progress. As for traction, through 1st its non existant, 2nd it hooks up at about 5 grand and just takes off from there. Admittedly, my suspension is set up for drift with stiff zeal coilovers all round (cant remember the rates off the top of my head). The best thing about all of this is the satisfaction I get from driveing something I built.
Milan: The car didnt even hit knock levels at 16psi which is all it ever sees now that I've sorted the boost control and it carries nice afrs throughout the rev range. On here its a pretty normal occurance to see rb25s running 300rwkw throughthe likes of gt30/40's and 35/40's on stock internals. But I still dont like running it internally stock, hence why I'll be getting an engine built within the coming months and then aiming for spot on 300rwkw (around 20 psi should see me there). Im just thinking to stick with the 25, or go 25/30 and a bigger exhaust housing, any suggestions?
Edited by ardie
wow thats unexpected , nice work khunjeng (mr cool)
you almost have even better response and with internal gate and stock manifold
not expected at all - nice work
youll notice the td06 has a fatter peak when it ramps up
but who has the mysterious td06 setup....
yeah thats what I wanted to comapre...cos I never have. different dyno's etc but I have build my cra from stock and the stock result was pretty much as expected so I think its accurate enough for a good comparision..
I suspect my CAS is dodge cos I'm getting inconsistant tunes..this result was the lastets b4 i buggered my leg. I will replace the CAS and go again. My guys reckon its not comming on hard enough...
thats on 1.2 bar btw.
bit of the thread hyjack! hehehe
if the cas is bugged your timing would either be in front or behind
that is the FC woudl expect your timing to be say 15 and it could either be say 10 or 20
so on max load ramped up you woudl be near 20deg ign timing but cos your CAS is off it coud be say 15 deg so its under and can do with some more timing or its over (say 25deg) and its on the peak of detonating but you should be making more power if that makes sense. basically the ecu and PFC dont know what the CAS is dialed in at so if its out of whack it thinks base timing is 15deg when it could be 12deg or 22deg. it bases its level of timing around that, so if its wrong you will either deontate your asss of at liek 15deg on max load (way too loo) or make f**k all power near 20deg timing (too high)
i had a guy email me a few times from some other state he was detonating his ass off and making jack all power and on max load he was near 10deg ign timing
its way too low and turns out the CAS he was using was off the planet so at idle PFC assumes 15deg but it was more like 5deg or something stupid
well anyway you get the drift - if the CAS is out of whack your timing wont match your power levels
most normal gtst's max around 20deg ign timing and make good power and a bit of detonation
if you make like 150rwkw and are running 20deg ign timing then your cas is off the planet and dialed backwards (ie 20 isnt 20 its more like 10)
    • Neg, the top one is actually for the front. The sizes are 18x10.5 +18 and 18x11 +32.   I measured many times but I'm sure I'll have problems as this is the thread for problems.
    • Just one thing; tapping tapered threads is tricky. Taps are always tapered and you would generally run it as far as you can, but with a tapered thread you have to stop much sooner otherwise the wide part of the taper will run in too far and you will have to thread the sensor in too far too as well (possible that it will never make a good seal) BTW nice wide wheels, I guess the top one is for the back!
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity. Edit: 11kg each (or 10.9/11.1 depending on what my scale decides over multiple tests, the 18x11 don't seem to weigh noticeably any more than 10.5)
