depends on cams and head work auto or manual what rear housing?
but to make over 400kw at the wheels i would use a gt42r did one on a friends car and in comes on full boost at 4500rpm and has made and easy an 600hp on 98 fuel
https://www.sau.com.au/forums/topic/179427-t04z/#findComment-3269515
What's your intended purpose for the car? ie strip / circuit / just a quick street car
Will the RB26 be in a manual or auto car equipped car?
TO4z with a 0.84 will do 400rwkw at a lower boost level than a 3540 with a 0.84 however I'd guess would reach full boost approx 600-800rpm later. My TO4z reaches full boost around 4600-4800 rpm in thrid.
https://www.sau.com.au/forums/topic/179427-t04z/#findComment-3269531
i get 20psi in 4th gear just before 4000rpm
garrett t04z with 0.84 and 6-boost manifold
https://www.sau.com.au/forums/topic/179427-t04z/#findComment-3271453
thats actually better then what i expected...what cams you have? I bet those 6boost manifolds relli do work huh?...Im thinking of getting the larger 1.x a/r for outright power. Its a rb25 with cams and headwork....Will the turbo drop off boost during gear changes? How much power varation between the .8x and 1.x a/r?
cheers
https://www.sau.com.au/forums/topic/179427-t04z/#findComment-3299436
    • I believe @Duncan has given it a crack at Mt Buller before (in actual race conditions)
    • All my Polish car culture insight comes from watching Nightride. So I half expect this to get 1UZ swapped eventually?! Are you going to drive it in winter? I'm always curious how ATTESA would hold up in the snow. There isn't that much opportunity to try it in Australia.
    • My steering lock unit on my Infiniti G37 has failed. The car is a local 2012 Infiniti G37 (Q60 ) I need to replace the unit My local mechanic said i need to buy a complete steering wheel assembly. Does anybody no any mechanics in Gold Coast or Brisbane who can fix this issue or where i can buy just the Steering lock control unit. Thanks
    • thanks, will conduct myself accordingly. i unfortunately put about 150 miles on the car before reading this thread again, however no PS issues, and definitely no turbo issues. it spools normally and still feels fast to me, probably because my previous car was an N/A auto sedan...gonna go fix the PS vacuum line though lol. safe to say, got what i came to this thread for. thanks
    • Agreed, I've never seen a 260RS specific manual. As GTSBoy said it will mostly be stagea other than the engine loom https://www.hgeconsulting.com.au/stageaservicemanual.pdf
