  • Replies 90
I was there too sitting pretty much next to where they were filming. We thought it was great they were out there filming legal drags, burnouts etc..
Of course they had to turn it into something completely against it...
I drove past all of those cars pulled over and they were less than a kilometre from WSID.. You couldnt even race on those streets as they are only one lane and quite busy once the drags are over. Couldnt really see them doing burnouts around there either but you never know I suppose..
hang on...
so they were at wsid - filming legal stuff, and have turned it around and made it into a bad hoon story again?
wtf?
I wish I could see the vid.
farkin gay media crap shit farkin
hang on...
Nope they were saying WSID = good. But cars speeding while exiting the facility = bad.
Video was made by benm... http://www.skylinesaustralia.com/forums/in...t&p=3265470
Yes that's Joe's both car at WSID
http://www.skylinesaustralia.com/forums/in...t&p=3265553
im famous!!!!! you can see me getting beaten and see me and my m3 in line a few secs after.
where do i go to get paid?
thanks turdy.
yep thats me and my m3 in that pic above, and in the vid earlier you can see me getting beaten by the green VL.
i catch up and beat him though :rolleyes:
ok maybe not. but i was close.
ok i lied again.
i guess those fools who was speeding right after the event is just asking for it.
I couldnt help but laugh at how sly the cops hiding with speed gun & alerting other hwy patrol to whom to pull over.
Yes its well homo, but come on, who seriously WOULDNT expect there to be cops waiting outside a racetrack.
Next week everyone should take a few donuts in their cars;
Cop: Do you know why i pulled you over son?
You: I was enjoying driving - it makes me happy. Here, have a donut, that should make YOU happy :rolleyes:
/sarcasm
Its ridiculous.. I cant believe people would even attempt to race/speed etc outside the track. they should of paid their $45 and done it legally earlier.
I still cease to believe they pulled 70 cars over for speeding/burnouts etc...
I was pissed off because I thought the footage they were filming was going to be used as a positive in the community for people actually going and doing it legally..
Instead they showed it as a reason for all the hoons to gather in one place and then go stupid after its finished..
Edited by Yidz
I am really pissed at police senior management for this.
There is no better way to push cars back INTO street racing than making the only legal venue, WSID, unsafe (ie don't go, you might get defected afterwards).
Idiots.
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
