Hey guys and gals of SAU, well if you have seen my thread with the recent results on the dyno then you may also be aware I want to build an engine to maximise the potential of my turbo setup as well as give me some peace of mind when I hit the loud pedal and when I take it for a thrash at the track.
Basically I'm after any information, experiences, knowledge or recommendations you guys have for me as I’ll readily admit I don’t know much about places to go, hence I need your help. I have chatted with a few workshops but I would like to hear some non bias (ok well probably more like LESS bias) opinions and recommendations from you guys.
To keep the peace, I’m not going to mention who I have and haven’t chatted too as I don’t want this to turn into a workshop war thread, nor do I want to play favourites. If you have anything negative could you please PM me as I am still interested, however I am well and truly opposed to slandering others names in the public forum.
Cheers
Ryan
https://www.sau.com.au/forums/topic/179554-engine-builders-in-vic/
  • Replies 62
racepace is nice, but if you don't own an rb26 i think its pretty hard to get work done on your car. it seemed to me that they preferred to work on rb26's which is unfortunate as they're a friendly bunch of ppl there who seem to konw their stuff.
Isn't Ray your tuner/mechanic??
Why not have a chat with him??
Hahaha remember in my 1st post how I said I have already chatted with some people............well yeah he MAY have been one of them >_< . Anyway, thanks for all the information so far guys. Basically what I really want to do is gather as much information from all the reputable engine builders in Vic, along with all the info I can gather from the forum and compile an outline of what I want for my rebuild as I know some places do things differently to others. The way I see it, I'll be able to "filter" out the necessary and unnecessary parts of the build and come to the best possible conclusion on what I do and do not need if that makes sense to you guys (it did in my head)
not sure about your experience but i never had any problems getting work done to my rb25, in fact Ben always comments its great working on my car being one of the best looked after cars he has seen.. >_<
Don't expect the builders to give away all their secrets....
And yes Benno prefers to work with GTRs... but it doesn't hurt to ask, if he likes you, you may get lucky :D
not sure about your experience but i never had any problems getting work done to my rb25, in fact Ben always comments its great working on my car being one of the best looked after cars he has seen.. :ermm:
Have a heard about your car, Ben speaks very highly of it.... :laugh:
LOL...as opposed to me. I think mine is more like the car John Candy drove in Uncle Buck :laugh:
I think the big bonus with the likes of Racepace and RE Customs is that you are using the person who built the engine to install and tune the engine. You make life hard for yourself using a certain engine builder, then to get it installed by your local mechanic or yourself. Then tuned by someone different again.
If the end result is less then you hoped its hard to pick if its the build, the installation or the tune. I always think the tuner will do a better job when they know exactly what it is they are tuning, and they know it has the right fuel pump, injectors etc etc
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
