Good morrow to you sir and one hopes for many happy returns on such an auspicious day as ones day of birth.
Rather. Tis true, such an occasion should be marked deservidely with thow own public day of holiday. Though, ye may not be chuffed at the suggestion that ye has circumnavigated the sun once more on this day. Ye should be grateful of acheiving such a feat none the less.
Sif not come par-taying with the mob on Saturday night. You missed a good one, Happy birthday mate!!
Bah, what have I done? SAU has gone all Shakespearian!
Worry, thou must. Thy journey on the downward spiral hath begun.
hmmmm.. what happened 9 months ago that aussies love to celebrate?
ohhhh valentines day was about 9 months ago wasnt it?
you are all valentines babies!! haha
oh yeh.. happy birthday!
close but no ciiiiiiiiigaaaaaaar
Happy birthday drunk-man
happy birthday love muffin. may your glasses stay un-fogged, and your cheeks rosy for many a year to come. and let's hope your RB26s remain in one piece for at least 12 consecutive months! :(
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
