Here some information about the nismo clutch (got from the nismo catalogue)
SUPER COPPERMIX
Allowable torque of 54 kgfm for dynamic friction (station friction: 81kgfm) Handles an estimated allowable power of 420PS
This is a single clutch system that takes "the ease of use"and "high power handling"forte of COPPERMIX to the next level.. This series also includes a lineup of standard specification products that can handle 380P
*NISMO standard measurements taken by combining high-power specification with the SR20DET engine.
Lightweight flywheel - Equipped with a lightweight flywheel manufactured form special chromoly, the ideal weight has been provided to ensure torque
Aluminum Cover - A cover made from a special aluminum with excellent heat-radiating powers is used
Center Plate with strap Function - To deal with unlikely occurrence of misshift, the center plate features a strap function
SUPER COPPERMIX TWIN
Allowable torque of 84kgfm for dynamic friction (station friction: 143 kgfm) Handles an estimated allowable power of 670PS
The multi-plate clutch takes "the ease of use" and "high power handling"forte of COPPERMIX to the next level
*The numerical values are NISMO standard measurement values measured using a push-type clutch combined with an RB26DETT engine. Evaluation were made based on street and circuit conditions. No quarter-mile evaluation was conducted
Uses an aluminum cover and lightweight flywheel as a set - A special aluminum cover weigh excellent heat radiation is employed. Also, this is combined as a set with a special lightweight chrome-molybdenum flywheel to achieve the ideal weight setting for the attained torque.
Hope it helps :)
Cheers Michael
thanks Michael but does this apply to the clutch kit also ? and 380P is that hp ? and whats 420PS mean. sorry i've got no idea on clutches. thanks
and what would be the difference between a copper mix and a non asbestos clutch ?
Edited by nsm034
thats good to know thanks heaps for your help :) micheal . heres a link to the one i'm looking at
http://www.perfectrun.com.au/performance%2...tsclutchkit.htm
i'd say copper mix is better because it's dearer. :mellow: would that be a fair asumption ? ha
Hey mate,
Im looking at the same clutch kit, they sell it without the flywheel for about $500 also. Just want to know, what are ppls thoughts on the advantages on a flywheel? Do you guys believe there are any power gains to be made on a dyno? From what I've read there is no dyno difference however on the street, it is like having 101lbs less weight on the street???
Edited by MR R34
I got a nismo twin plate + light flywheel and I hate it. Way too on off for city driving. I'm going to get it replaced by a single - already have nismo slave so should be heaps better for traffic.
Is this a Super Coppermix, or a G-Max or earlier clutch? Just trying to figure out which one you have coz the Super Coppermix is supossed to be the ducks nuts
Let me know if you wanna sell it
It's a Nismo Gmax Item - I'll have to find the version number. It's not too bad while your moving just annoying to drive to and from work and stopping at lights etc. Which is basically 90% of my driving - I'm rebuilding engine at the moment so I'm keen to replace it with a decent single.
  • 2 months later...
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
