If your able to make it your self it will cost 1/4 of that cost. :)
~$40-50 for welding the 2 bungs in for the bov and breather then a little for the pipe (~$20) + 2 bits of silicon.
If the pipe is in 4" stainless then for a 90degree bend its around $40.
when i did mine i didn't have the catch can and i had the bov hooked up, would've been so much easier for me to make if i'd had the catch can on and the bov d/c like i do now. haha, heinsight's a wonderful thing!
Hey Ash,
Once all tuned up does yours fart and carry on with the bov blocked off?
At the moment untuned mine randomly when coming off the throttle to change gears pops and farts; drivability is fine; very little afm reversion and no stalls. I'm thinking off hooking mine up just to get rid of the popping and farting incase a mr police man is sitting behind at the time. :S
Cubes, I got my turbo 2 afm pipe on with my stocker blocked for the moment with no atmo BOV and it has a catch can installed.
I get backfiring, etc, but its a combination of my 02 sensor dead (reads like 0.02v at idle and randomly goes to 0.30 and then back to 0v while driving) and I have all those mods on stock ecu.
Kind of off topic but while on the topic of catch cans. :thumbsup:
I'm running twin catch cans temporarily to see how much it breathes. If its all good I'll be plumbing it back in. :) lol Reason for twin catch cans is its not as obvious.
So far its all super clean; not a single drop or smear of oil in the can or in the pipe its self. The single 1.5mm restrictor is definitely working well. :(
Pics...
Drivers side u can see how I've T'd in to the cam cover to PCV valve. Its just for looks; the PCV is blocked off.
Passenger side u can only just see the coke bottle with the hose going in to it. Both coke bottles have a modified top so they can breathe and filled with s/steel scourer. Hopefully I can't plumb it all back up as I really don't like catch cans due to being a big hit on the defect list.
If your O2 sensor is reading lean constantly unplug it.
Its telling the ecu the mixture is lean so the ecu dumps in more fuel. Your better off with it disconnected. From memory with it disconnected cruise afr's are around the 13:1 mark which isn't so bad.
Apart from the usual sponge and spray over at car lovers/BP no. :)
It looks clean as I just put it back together; I had the head off to be sorted as well as head oil restrictors and new turbo bolted on.
Give it a month and it will look normal again. :thumbsup:
Speaking of O2 sensors, I filled up last week and got a solid 350km out of her, I think mine could be on its way out....lol I could've sworn i replaced it about 2 years ago. How often have people been changing thier 02 sensors??
Hey Ash,
nah mine's fine apart from stalling after a while of driving and it defintiely runs richer but once tuned she'll be all sweet, i'd probably run the bov in your instance, u dont need any more response, hehe!
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
