For the R32 gtst (and maybe others?)...
Some numbers and other stuff to help with service parts:
Factory oil specs: 7.5w30 (but any rating as long as its synthetic / semi-synthetic is ok), 4.6L capacity
Oil filter: Z145A
Fuel filter: Z387
Spark plugs: PFR6A / PFR5A (NGK platinum) - gapped to 1.1mm or 0.8mm if you are missing
Tyres: 205/55/R16, 32psi - check the spare as well!
Water pump: 21010-21U25
Coolant: antifreeze-antiboil at 50:50 concentration, 9L capacity
Thermostat: 21200-42L05
Timing belt: 13028-20P10 - should cost around $80 mark
Hope this helps as lots of people post about this stuff all the time
I have collated the information as i see it and recorded it into a book for myself but decided to put it into the FAQ section to help everyone :)
Waz.
https://www.sau.com.au/forums/topic/18066-r32-maintenance-parts/
  • 3 weeks later...
  • 4 weeks later...
ripped from www.rb20det.com
Water Pump: 21010-21U25
coil Packs: 22433 60u02 mcp-300124
Oil Filter Genuine Nissan: 15208-H8911
Oil Filter Ryco: Z145A
Oil Filter Valvoline: R9
Oil Capacity: 4.6L with filter (7.5w 30 is recommended)
Coolant Capacity: 9L
Manual Gearbox: 2L (80w 90)
P/s Fluid capacity, non-hicas: 1.8L
Sump washer 11026-01M02
Fuel filter 16400-53J10
Rear diff oil 1.5L
Alternator belt 11720-24U00
Cam belt 13028-20P10
PAS belt 11950-04U00
NGK standard plugs PFR5A-11 1.1mm gapped
NGK Iridium plugs T7341T-8 0.8mm gapped
Trust-Greddy Iridium plugs IT08 0.8mm gapped
Brake pads and discs for r32 gtst are the same as s13 200sx
Speedo drive gearbox end 32702-58S21
Air Flow Meter 22680-02U00
  • 1 month later...
  • 5 months later...
  • 1 month later...
  • 1 year later...
ok,when my car was up on the hoist,i noticed like a drain plug at the bottom of the diff, is there one at the top aswell?
is there also a drain plug at the bottom of the gearbox?
automatic transmission
Edited by RSTME
yep one at the top, if u have a big exhuast then u might have to remove some section IIRC, i think the plugs take a half inch braker bar, maybe its 3/8
anyway, with auto trans it gets a bit more complex as your best removing the sump, and changing the filter inside etc, if your not comfortable with it, id reccommend getting somone to do it for you, sorry for the quick replys im dead, any questions feel free to pm
also, when draining things like diff always crack the fill before the drain, because if you undo the drain and the filler bung is stuck then you have a headache.
Edited by Jolinator
you'll find that the actual sensor is the same (titania, 3 wire, 12mm thread) - the only difference will be the connector type and cable length.
Another 'compatible' sensor is the OTD2F-B2 which originally suits an R31. If all you're after is the sensor, you can cut/splice/solder into the existing loom...
:D  I thought the part number for an NGK O2 sensor to suit a HCR32 was OTD2F-P1P ?!?!
  • 1 month later...
Z32 turbo and R32 turbo brake part numbers are the same.
DBA 909 & DBA 908. Same as the pads. Both the same part number.
My uncle bought a NA Imported Z32 which had slightly thinner disks.
Wrong, Only gts-t Type M has the 4 piston caliper like the z32.
Regular gts-t like mine, have the s13 200sx brake.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
