Hi,
I'm looking at upgrading the lsd on my r33 (as it no longer works) i've worked out which brand i will be buying (NISMO) but i'm not sure weather i should go for a 2way over the 1.5way.
The car is daily driven, and most of the track time i see is grip events but i dont mind a drift event here and there. Is there any major loss in going for a 2way compare to the 1.5way?
CHeers Michael
https://www.sau.com.au/forums/topic/180798-2way-vs-15way/
well a 1.5way is still a 2 way. just weaker on deccel (which is good unless you like backing it into to corners all the time). up to you. if you are hard core into drift then a 2 way is the go.
https://www.sau.com.au/forums/topic/180798-2way-vs-15way/#findComment-3286663
hmmm, what do you mean by backing it into a conrner?
will i have more chance of braking traction with a 2way into corners ?
https://www.sau.com.au/forums/topic/180798-2way-vs-15way/#findComment-3286709
1.5way for a street/track car <-- I use a Kaaz, and it's great!!
2way for drift only car
I have heard of too many accidents with 2way diffs on the street.
Under acceleration both are equal, but under deceleration the 2way will lock just the same as acceleration but the 1.5way requires more force to lock the second wheel. This 1.5way allows you to coast through round-abouts and turn corners easily without having to take it out of gear.
https://www.sau.com.au/forums/topic/180798-2way-vs-15way/#findComment-3287073
thanks for the reply Al,
i was abit worry about the 2way lsd as i've driven a 86 with a 2way kaaz and i found it extremely easy for the rear end to come out when turing but i wasnt too sure if it was just the lsd or the car setup
https://www.sau.com.au/forums/topic/180798-2way-vs-15way/#findComment-3287493
a 1.5 way is much better suited to track work (for ameture track work) because they dont lock up as easy under de-acceleration but remember you have a certain amount of clutch/shims you can put in the diff (the clutch packs for the lsd) to make it stronger/ weaker in its lock up . there wouldnt be alot of difference in them if people knew how to set them up properly :D (on a side note, did you know that v8 supercars use a full spool) , it comes down to your driving style/skill in the end for the decision
https://www.sau.com.au/forums/topic/180798-2way-vs-15way/#findComment-3289813
Under acceleration the 1.5way and 2way lock up at the same rate: Provided they are the same make and have been set-up the same, with the same amount of shims.
The difference is only under deceleration.
https://www.sau.com.au/forums/topic/180798-2way-vs-15way/#findComment-3290012
Do you drift exclusively? No, then get a 1.5 way. Yes, then get a 2 way.
If you get a 2 way and you track your car then you will be driving around the diff on corner entry as it will unsettle the car in anything but a straight line when braking/decellerating. Which means any corners where you have to brake in a curve, arse end tries to come around so you are backing it into corners as Beer Baron has already stated. It's great if your car is an understeery pig as it gets the nose in, but otherwise just a pain.
For occasional drift the 1.5 way will do the job. It just means you need to initiate the slide a bit differently. Plenty of guys drift with 1.5 ways.
https://www.sau.com.au/forums/topic/180798-2way-vs-15way/#findComment-3291231
i hate the kaaz diffs, bear in mind if you buy a decent diff many are 1.5way and 2-way switchable. CUSCO for example do this and NISMO also has the ability to do this and to tune the torque preload WITHOUT removing the diff. i hate the whole kaaz feel and design.... just in case you missed i the first time :rofl:
https://www.sau.com.au/forums/topic/180798-2way-vs-15way/#findComment-3293177
I totally agree that the Nismo diff is better. But i got my diff from an Australian supplier at a very reasonable price (fair bit cheaper than Nismo) and it does the job VERY nicely.
Agreed. Got mine for $800 new and its good enough for my thrashing around...
I havnt driven it cos I ripped my achillies and on crutches for ANOTHER 4 weeks... no deca driving for me, will come down though Al with Alan.
https://www.sau.com.au/forums/topic/180798-2way-vs-15way/#findComment-3294850
    • About $4k brand new, available from vendors in Oz, or via an importer from Japan. Although that is for an R34 box, so you also need to buy the push clutch front plate (brand new from Nissan) and swap that over, and drill the bellhousing for a push clutch slave cylinder.
    • Absolutely could be. I collected data logs from when the O2 sensor was still out and also after I had replaced it so will try to compare them. Pretty confident that the affect is lowered with the new sensor, will check logs at the same RPMs/conditions.
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
