I read the specs on the stagea a while back as I am havin a good think about getting one someday, and wondered what they perform like in the everyday carpark scinario. Turning circle in the specs = 5.3 metres, and that's huge! Can you get a steering rack that makes the turning radius smaller?
https://www.sau.com.au/forums/topic/181049-stageas-in-carparks/
Huge? are you used to driving a barina or something?
Turning circle is hardly a factor i'd decide whether a car is good or not. I mean, I have a skyline - same gear. I have never found it a PROBLEM. e.g. I don't go oh shit, ran out of steering lock when trying to park...
In answer to your question, yes you can
Barina - no. Ford Laser - yes. it has...or should I say - had, a nice small turning circle. Thanks for answering the question too. I don't rate it steering as a major factor, but thought i'd throw the questions out there.
Well, as a direct comparison to my last car (eb falcon) I think the stag parked beautifully. Before you compare it to a laser, you may want to compare the wheelbase and interior space too.....
The Stagea has a pretty decent turning circle considering the fact that there are drive-shafts running to the front wheels too (unless you go for a RWD version). I came from a Corolla, and my old man still has a 2003 Camry. The turning circle on the Corolla was great (obviously, because it was a small car), but the Camry's turning circle is worse than my car's...
One thing with the Stagea is the rear overhang, but what's good is that the rear window is almost vertical, so it's pretty easy to judge how much room you have behind you if you reverse park into a spot. It's also good because it makes the load area much more useful, compared to a hatchback or a wagon with a steeply-sloping rear window area.
FFS you buy a car and you are worried about the tunring circle? Forgive me for saying this but how long have you had your license for?
In a car thats 4wd the turning circle is going to be always a large one. It doesnt mattes wheter is a sedan or suv. Why? Like they say theres Cv joints in the front wheels that drives it. Thats the factor that limiting the turning circle. Get it?
Driving skills is all you need to drive in a car park. One advise when driving such a long vehicle always go for a rear entry :P:D . Which means rverse in instead of parking head in first try it.
Rather than start a new topic i'm going to follow on with a similar question:
How's the reverse parking go with the Stagea? I'm coming from a Subaru Liberty Sedan and it's easy enough to park in tight spaces - I"m guessing Stag's aren't too bad in that respect?
Like I mentioned above, Ian, having a good-sized rear window and an almost vertical tailgate helps heaps. You know that if there's roughly 2ft to the rear window from a wall, that roughly half of that should be left for the bumper. Of course, if you're gonna open the tailgate later to get the shopping in or whatever, don't forget to leave more room.
I find it enormously better than my 70 series Supra in carparks, for the simple fact that the Supra's doors are about 3 km long, and you had to take at least 6 months of yoga before even contemplating using anything but the aerotop for ingress/egress. Sure, the turning circle is a little wider than a Lotus Elise, but it's a Large car!
Ive never had an issue in a carpark and ive had to park in some stupid stupid spots.
On another note, want more lock, get aftermarket tie rod ends and adjust them for more lock, then a wheel alignment to adjust toe.
Otherwise, remove the rod ends and insert some spacers, aka washers, when screwing the rod end back in. This will do the same thing but in a less safe more borro drifter kinda way....
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
