Hey Guys,
Starting a thread of posting your car's Audio Install's.. Show us your specs and your pictures
Use the template bellow.. And Insert your details and photos.
Have Fun :thumbsup:
 [i]Specs:[/i]
[b]Headunit:[/b]
[b]Front:[/b]
[b]Amp:[/b]
[b]6x9:[/b]
[b]Sub Amp:[/b]
[b]Sub:[/b]
[b]Capacitor:[/b]
[b]Wiring:[/b]
[i]Car:[/i]
[b]Make:[/b]
[b]Model:[/b]
[b]Year:[/b]
[i]Pictures:[/i]
<---Insert Here--->
Edited by fadinmist
https://www.sau.com.au/forums/topic/181506-your-audio-install-picturesspecs/
  • Replies 104
i'll start :thumbsup:
Specs:
Headunit: Pioneer DVD Touch-Screen
Front: MTX TDX-6502
Amp: MTX Thunder 3404
6x9: MTX TDX 6903
Sub Amp: MTX Thunder 3401
Sub: MTX Thunder 7500
Capacitor: None
Wiring: 4Ga Powers - 12GA Speaker Wire - 3 x Audioline RCAS
Car:
Make: Nissan
Model: Skyline R32
Year: 1993
Pictures:
Edited by fadinmist
Specs:
Headunit: Kenwood DDX6019
Front: Earthquake fc6.2 (600watt)
Amp: Earthquake ph2200.4 (4x175WRMS 4Ohm)
6x9: Earthquake EQ-693r (800watt)
Sub Amp: Earthquake PH5000d (5000 watt)
Sub: 2x Audiopipe 1000 WRMS DVC candy subs
Capacitor: 25 Farad power accoustic + 6 Farad power accoustic
Wiring: 1x run 0awg to 25 farad cap feeding monoblock, 1x run of 4awg to 6 farad cap feeding 4 channel
Car:
Make: Suzuki
Model: Swift Gti
Year: 1995
Pictures:
Edited by nemz
Specs:
Car:
Make: Suzuki
Model: Swift Gti
Year: 1995
Pictures:
Hahah NEMZ man, that car is going to flip once the bass hits :)
Nice install but, must sounds mint.
Thanks,
Abu
Edited by abu
Specs:
Headunit: Clarion DXZ766MP
Front: Alpine DDLinear splits
Amp: Alpine PDX-4150 digital amp
Rear: Alpine DDLinear's
Sub Amp: Alpine PDX-11000 digital amp
Sub: 2 x 12" Alpine Type R
Capacitor: 1 farad
Wiring: lots :thumbsup:
Car:
Make: Nissan
Model: Skyline R33
Year: 1994
Pictures:
Custom Boot:
post-15008-1187692025_thumb.jpg post-15008-1187692072_thumb.jpg post-15008-1187692109_thumb.jpg
Custom Parcel Shelf:
Tweeter Position:
Specs:
Headunit: Alpine IVA-D310E
Front stage: Boston Acoustic Pro60
Powered by: Audison LRx 2.5 amp
Sub: ID Max 12 Dual 2Ohm
Powered by: Audison LRx1.4 amp
Wiring: 0/4Ga + Stinger
Sound deadening: lotsa Dynamat
Built & tuned for SQ but it still pumps out some nice SPL :thumbsup:
Pictures:
post-25499-1187685828_thumb.jpg post-25499-1187685835_thumb.jpg post-25499-1187686200_thumb.jpg
Edited by G_Force
Specs:
Headunit: JVC DVD Unit and 7" VGA Touchscreen Moulded into the dash Air con controls moved to where the ashtray used to be
Front: Haha still stock
Amp: Running off the deck
6x9: stock rears
Sub Amp: 600wrms alpine
Sub: 2x 12" Alpine type S
Capacitor: no need they do more harm that good
Wiring: 2 Gauge to the amp rest for now is stock
Car:
Make: Nissan
Model: R32 Skyline
Year: 1990
Pictures: Still to come car is in the shop at the moment
Specs:
Headunit: Carputer, interface via Xenarc 7" touch screen
Front: Rainbow SLC265Kicks
Amp: TruTechnology 4ch
Sub: Rainbow 12" Amboss
Sound Deadening: Dynamat extreme to inside and outside doors skins, Dynaxorb mats
Car:
Make: R33 GTS-T Series II
Year: 1996
Pictures:
Edited by Trav33
Specs:
Car:
Year: 1996
Rainbows & Tru Tech... must sound sweeeetttt....
  • 1 month later...
is this worthy?
That's not bad, nice install, pity about the gear though :spank:
Maybe sell the gear, get a nice 1000watt RMS amp and a IDQ12 :P for some real kick arse sound :rofl:
Also lose the farrad capacitor on small systems like that they don't do much at all to be honest
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
    • They have said food will be limited. Mainly meat pies and sausage rolls from memory. But they have a coffee van!
