do a search in forced induction this question has been asked about 20million times
yeah, with a million different and rather generic answers
i'm looking at boost controllers right now infact, the 3 on my list are:
greedy profec b spec II
apexi power fc boost controller kit, and
Blitz SBC Spec R - Dual Solenoid
going through all the pros and cons of them, i think the power fc add on might win because i really dont want controllers sitting in the car
but the summary from the threads on SAU is that the blitz dual solenoid controllers are the best and hold boost the best (the spec r is the entry level controller for that range)
and the greedy is sitting on top of my list because i asked shaun from boost worx what he would recomend, and this is the one!!
i think its going to come down to the greedy vs apexi, i just want some more information on them first =)
hope this helps
Edited by Fishpaste~
https://www.sau.com.au/forums/topic/181781-ebc/#findComment-3301571
The main point was to see what guys from Adelaide use, not so much which is better, just threw that in so the thread isn't too boring.
pfc
btw, arent u selling ur car?
Yeh its not for me, its just i was discussing it with a friend and wanna see which ones get used the most.
Fishpaste, what about EVC 6 ?
https://www.sau.com.au/forums/topic/181781-ebc/#findComment-3301586
ok i use an avcr, its unreal great for higher power applications in its ability to be able to control boost per gear by rpm etc etc. The pfc kit is a waste of money for what it is unless you can get one cheap, all you can do it select one boost and thats it you cant control the duty etc etc.
Edited by sinistagtst
https://www.sau.com.au/forums/topic/181781-ebc/#findComment-3301676
I agree Dan, having used the AVCR on my previous ride I will say it was better but when I got my car it already had the PFC boost controller kit on it so I saw no point in changing unless I want to chase higher power levels (who doesn't though, right :) :))
https://www.sau.com.au/forums/topic/181781-ebc/#findComment-3301723
avcr here, so far so good after Dan installed it for me. How's them beer's?
will know more of how it performs after my tune but after fiddling with it and reading the aussie manual for a while the other night i'm very impressed with all the features it has!
https://www.sau.com.au/forums/topic/181781-ebc/#findComment-3302113
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - there is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
