do a search in forced induction this question has been asked about 20million times
yeah, with a million different and rather generic answers
i'm looking at boost controllers right now infact, the 3 on my list are:
greedy profec b spec II
apexi power fc boost controller kit, and
Blitz SBC Spec R - Dual Solenoid
going through all the pros and cons of them, i think the power fc add on might win because i really dont want controllers sitting in the car
but the summary from the threads on SAU is that the blitz dual solenoid controllers are the best and hold boost the best (the spec r is the entry level controller for that range)
and the greedy is sitting on top of my list because i asked shaun from boost worx what he would recomend, and this is the one!!
i think its going to come down to the greedy vs apexi, i just want some more information on them first =)
hope this helps
Edited by Fishpaste~
https://www.sau.com.au/forums/topic/181781-ebc/#findComment-3301571
The main point was to see what guys from Adelaide use, not so much which is better, just threw that in so the thread isn't too boring.
pfc
btw, arent u selling ur car?
Yeh its not for me, its just i was discussing it with a friend and wanna see which ones get used the most.
Fishpaste, what about EVC 6 ?
https://www.sau.com.au/forums/topic/181781-ebc/#findComment-3301586
ok i use an avcr, its unreal great for higher power applications in its ability to be able to control boost per gear by rpm etc etc. The pfc kit is a waste of money for what it is unless you can get one cheap, all you can do it select one boost and thats it you cant control the duty etc etc.
Edited by sinistagtst
https://www.sau.com.au/forums/topic/181781-ebc/#findComment-3301676
I agree Dan, having used the AVCR on my previous ride I will say it was better but when I got my car it already had the PFC boost controller kit on it so I saw no point in changing unless I want to chase higher power levels (who doesn't though, right :) :))
https://www.sau.com.au/forums/topic/181781-ebc/#findComment-3301723
avcr here, so far so good after Dan installed it for me. How's them beer's?
will know more of how it performs after my tune but after fiddling with it and reading the aussie manual for a while the other night i'm very impressed with all the features it has!
https://www.sau.com.au/forums/topic/181781-ebc/#findComment-3302113
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
