Wondering if any Townsville peeps know of any local tuners that deal with NIStune? And by that I mean quality tuners (not Xtreme :s)... Sucks being regional, we miss out on top tuners that you metro guys take for granted. Maybe I should take a trip down to EFI on the Goldy??
https://www.sau.com.au/forums/topic/181930-nistune/page/9/#findComment-4898193
ive got a nistune board in my 32. the car was runny very rich, and sloppy before the nistune (fmic, full exhaust, splitfires, 14psi blah blah blah) cold starts were shit, and it idled like a dog until the engine was hot, now with the tune, installed and tuned by mercury motorsports in brizzy, power is more apparent thru the whole rev range, idle is very smooth, better fuel economy, gained about 10kw at the wheels, but its just a nicer car to drive. i would deffinately recommend this product, as it does such a great job, easy to tune, and very reasonably priced. adam
Edited by adamskill
https://www.sau.com.au/forums/topic/181930-nistune/page/9/#findComment-4900774
Good to see my old thread alive and kicking still. Im on my 3rd Nistune board now. Using an Rb20 ecu to run my rb25 starts fine drives ok just need to tune her now.
Direct bolt on no stuffing with wires i just need to hook up a vct controller now
https://www.sau.com.au/forums/topic/181930-nistune/page/9/#findComment-4900879
Recommend you look into some sort of device to read the revs and turn the VCT on and off, will add performance all through the midrange. I will be working on a product to do this exact thing in the coming weeks/month, but there are already devices out there that will do this.
https://www.sau.com.au/forums/topic/181930-nistune/page/9/#findComment-4900996
Im looking at using an atmega chip to do it.
Should be to hard to count rpm and output a signal
Im doing the same with with a PIC (very similar to an AVR) you can get chips that convert a frequency signal into an analog voltage, will save you doing the counting in software and can just read the voltage with an AD module, might make it a bit simpler, that's how I plan to do it.
https://www.sau.com.au/forums/topic/181930-nistune/page/9/#findComment-4901407
Care to share any details on this chip?
https://www.sau.com.au/forums/topic/181930-nistune/page/9/#findComment-4901764
i dont know much about how the vct but just thought u could maybe hook a shift light up to it as in u could adjust the shift light to light up at 4500rpm or whatever revs you want the vct to turn on at, then just remove the bulb and hook the + and - terminals from the shift light bulb to the vct,
depending on voltage requirements for the vct and how its set up it could in theory work
https://www.sau.com.au/forums/topic/181930-nistune/page/9/#findComment-4903966
I doubt the shift light would beable to supply the power requirements of the VCT solenoid by itself, but if you hooked it up with a transistor and relay it should work.
You can buy purpose built frequency-voltage conversion IC's. Alot of the manufacturers will send samples (saving you having to order 100 at a time).
https://www.sau.com.au/forums/topic/181930-nistune/page/9/#findComment-4904550
doesn't VCT work by grounding
and doesnt it turn off in the higher revs
my knowledge is limited here
Yes the VCT should be turned on from 1500-5000rpm, if you leave it on in high revs you will LOSE power not gain it. We are advancing the intake cam here.
Using a shift light would be too slow an inaccurate, the easiest way to do it is with a small microprocessor. When I have time after uni, only a few weeks away I will be working on something which I will make available to people for this purpose.
A relay would be far too slow to turn on and off at the speeds we need, you need to use a FET.
http://www.national.com/mpf/LM/LM2917.html
You would use two and set them up for the lower and upper rev limits and use two ADC channels on the PIC, I think this would be the simplest way to do it. I haven't looked at the datasheet in detail but it should be sufficient for the 10hz-8000hz signal we will be seeing.
Does anyone know if the tacho signal is a square wave or a sine wave?
Edited by Rolls
https://www.sau.com.au/forums/topic/181930-nistune/page/9/#findComment-4904830
Will the Nistune have to be tuned after i get the Cam Gears put in?
Not necessarily, though helps to have the car on the dyno and adjusting them there and then to see if the adjustments made any difference or made things worse.
https://www.sau.com.au/forums/topic/181930-nistune/page/9/#findComment-4905453
  • 3 months later...
saves starting a new thread,
just about to either get a ecu remap from Ceff1e or DrDrift.
i live in adelaide so there in melb but is it ok to get a remap mailed out?
can the remaps be re-tuned after like a pfc? or do they need a whole new remap?
i would love to get my car over to vic for them to tune but this is not going to happen, well not for now.
so would i be safe to get them to remap and send me out my ecu?
cheers
https://www.sau.com.au/forums/topic/181930-nistune/page/9/#findComment-5070398
cheers
Do you know NISTUNE is Adelaide based? Speak to Pete or Matt they could direct you to a recommended shop there.
https://www.sau.com.au/forums/topic/181930-nistune/page/9/#findComment-5070428
didnt know that,
i know boostworx here in adelaide do them.
but i have herd the best things about DrDrift.
can they be re tuned?
coz paying $600 everytime i change a mod on my car is abit hefty.
otherwise i was thinking microtech.
https://www.sau.com.au/forums/topic/181930-nistune/page/9/#findComment-5070436
didnt know that,
do yourself a favor and call nistune, the ecu if it is a nistune remap can be retuned infinitely. We charge an upfront tuning fee then charge by the hour for retunes later on. Sam is very good at remapping and we send alot of westside (melbourne) enquiries to him.
Forget the microtech, adaptronic would be money better spent.
https://www.sau.com.au/forums/topic/181930-nistune/page/9/#findComment-5070501
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
