Mine came with a sunroof, but factory. Im a bit sceptical about an aftermarket sunroof. Don't know if they are any good these days but apparently they start the leak.
You are best to shop around and ask a few professionals. You might be looking at about $2500.
they start at $2500 and go up from there. best to find a shop that specialises in them.
i rand a few places in sydney like.. sunroof centre.. all specialises in sunroof.. quoted 1500- 1800.. which is not too bad but just a bit scared that it might be a problem in the future..
a sunroof isn't like a targa top or a convertible.. the centre of the roof isn't a structural point of the car, its the A/B/C pillars
so essentially it will not affect the chassis rigidity at all. but it probably requires an engineering certificate as you're cutting a panel
as far as reliability goes, well you should be right from teh stories i have read about sunroofs.. the stock one is tiny anyway so anything aftermarket it going to be better than thestock thing in my opinion
cheers,
Warren
mate of mine did a sunroof on his R33 SII a while back. $1400
only problem he ever had was the closing switch got stuck once and drained his battery overnight.
thats prettymuch it. no leaks etc..
the place in perth deal with holdens/ford new ones and this is the kit they install in those cars, apparently.. well this is when VX's were everywhere or was it VT's
So i do not think its a big deal if they are offering a warranty.
  • 6 months later...
It's small. Trust me.
I had a sunroof on my r33 and nothing near as big as a other decent size factory sunroof on other cars. Probably not worth passing on the chance to buy other good cars at auction just for the sake of a nissan factory sunroof.
On my old car it didn't (or hadn't) leak yet but I've been told of others who had sunroof in their car and they are prone to leaking.
Might be a good consideration to get a Nissan without sunroof - save you the long term hassle. But again V35 is a newer model so you may get away a number of years before it may start leaking - which is time for you to sell.
thank you very much :wave:
  • 1 year later...
I'd rather something like this personally...
vinyl overlay, just peel it off if you don't want it anymore, his sunroof is real btw
I would never get an aftermarket sunroof personally, my old r34 had a factory sunroof and it was top quality, never leaked.
Used to work in the car industry and the aftermarket sunroofs that were sold by the aftermarket girls (the one you're introduced to after you buy a car and try to upsell paint protection etc.) were shoddy as hell and looked out of place on the inside of the car. Cheapened it in my opinion
might be different for companies that specialise only in sunroofs but even then how I'm skeptical
don't let me deter you though, just my 2c on the subject :)
Edited by Yo-Yo
    • jeebus. glad you weren't under it while performing the stunt. Also thanks for the link to the wheel measurer, exactly what I needed
    • In the older stuff there were very significant differences 2wd to 4wd, for example Stagea had strut front end for 2wd and double wishbone for 4wd so it was not minor to swap. From poking around the 2wd v37, it *looks* like it might be more possible; some of the parts specifically have "2wd" stamped on them which suggests the platforms are more similar. You'd still want to start with a 4wd half cut to swap stuff from though. I'd suggest if you don't have a tune on the ECU you don't really need one on the trans either. Throttle mapping is in the ECU side (and you can always use a Roar Pedal if you want the throttle to actually respond to your foot), and really if you are happy with the stock power you probably accept the stock trans behaviour too....its all made to be "sporty" not racey.
    • So, updates. I have not washed the car since it came back from Tassie. I've driven it around a bit but not got around to actually sorting it out. I DID raise it because I cracked the rear bar leaving a hotel which was very distressing. Interestingly, the car drives more compliant now that it's raised a fair bit (5mm front, 15mm rear). Also noticed that my FR height was 10mm lower than FL. So that's now sorted out, too. I also bought this and had it printed: https://www.etsy.com/au/listing/1576422240/wheel-and-tire-fitment-tool-universal?ref=shop_home_feat_1&dd=1&logging_key=08f604d9fa4cc383550ba985e6ac85cd5cac7fbb%3A1576422240 Now, if I was smart I would have taken my brake calipers off to actually use this correctly but it was evident enough to me that in the region where the caliper was... there was nothing to hit suspension/guard/arm wise. So I'm going with "it'll be fine" after using the tool to hopefully very precisely measure the wheel clearance. Also while doing this, I had the very VERY bad idea of jacking one of the wheels/suspension arms up while the rest of the car was on jack stands. I did this to see how the arm would travel. This all was well and good until the car slid off the stands and went through a fence. So don't do that. Incredibly nobody was hurt and there was only minor damage to the rear bumper as the car didn't have far to slide, and had 3-4 wheels on it. The only damage turned out to be the fence itself which was easy to fix, and a little bit of damage to the fibreglass rear bumper trim. I had already planned to try a touch up paint kit to fix the time I drove into my garage door to see if it'd help in the interim before I get it fixed properly. I used the Dr Colorchip kit after looking online and seeing everyone talking about it. Yes it's made for chips and not huge broken missing pieces and I'll be 500% recommending it for stone chips after using it for stupid things like me. This took about ... 10 minutes and looking at the half assed photo the 30 second job I did on the bumper corner was almost perfect just by using the tiny little brush and painting it in. The sealact stuff to remove over-painting is really useful, so if/when I do it again I'll likely slather the touch up paint well over it and then clean it up with the cleaning solution. The wheels should arrive in a couple of weeks. I am still kinda confident after doing a stupid amount of measuring (and borrowing a set of 18x10.5+15) that they will not fit because I overlooked something, somehow and flew too close to the sun. ALSO R34 GTR guard liners do not fit on a GTT. I bought the undertray brake duct guides and had the wonderful problem of them not fitting my intake, my oil cooler and the liners themselves were even worse. Attempting to fit them won't work in general - You would have to cut them up as another poster mentioned as the bodywork is different on the GTT. At least I can try to resell them. So instead of cutting those up, I cut up my old already-cut-up GTT liners and extended them by using some PP plastic and drilling some 8mm holes for some nissan clips for the 'extra' bit. Because I was happy to cut them I was able to mount them pretty damn forward so I now have some semblance of guard liners, and the brake vents seal the bumper from the bottom. It sort-of-looks like this, to give some idea - If you look at the GTR and then the GTT this is when I realised that I needed to seriously measure as the inside of the rim area is entirely, entirely, entirely different and could not take any internet measurements for granted.
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
