Proudly sponsored by Nulon.
SAU-Vic in conjunction with the WRX Club of Victoria is once again lining up to see who can do the biggest burnouts, make the most noise, and i suppose go quick to boot
Date: Sat 6th October
Venue: Heathcote
Time:
Gates open - 9am
Scruteneering - 10am
Racing starts - 11am - 4pm
Cost: $40 to race. $15 to spectate.
Payable on the day at the gate
Car must be roadworthy to pass scrutineering and you must be suitable dressed with ankle to wrist, non flammable materials. Helmets and proper footwear are required to participate on the day.
The day's emphasis is having a good, fun day out. So bring family and friends.
Food and drinks shall be available at the Heathcote Kiosk.
Classes are as follows:
- AWD Nissan / GTR Class
- RWD GTS-t Class
- WRX/Mitsubishi Class (VR4 Galants, GSR Lancer, 300GT/GTO etc)
- STi/EVO Class
- Intruder Class
- I have NO Class Sh1tbox Class
Trophies will be awarded to the fastest SAU Vic / WRX club member in each class.
Prizes kindly donated by Nulon will be awarded to the fastest SAU Vic member in each class. Prizes consist of:- oil, coolant, octane booster, engine conditioner, plus more.
  • Replies 52
