Only had my car about 2 and a half weeks, however i got a turbo timer which the car wasnt ment to have. It was hidden up in the steering column.. Also i was removing the gear stick boot and founds a big phillips head screw driver. Also my ash tray was full of dirty asian ash and i had remains of asian water with my spare tyre. But i havent looked in door trim or behind the back seats or anything yet...
Further on from this.... I got my car tinted yesterday and when the tinter removed my door trim he found a weird asian menu along with a few Jap receipts from an Electirical store.... The guy bought DVD - RH for 9110YEN.... so thats $91.10 i guess it was fora DVD player and not just the blank discs hey....
  • Replies 119
When I ripped out the seats in the 32 GTR I found a few coins of Yen and a whole heap of fluff, I still have the parking permit on the rear window and the Jap rego on the front window.
Also found a Jap-model Turbo timer under the steering column tucked up. It still works, it was just turned off! I can't work out how to use it properly, so I just disconnected it.
This thread has me curious now, though! Tonight I'm gonna rip off the door trims and search in the boot haha
Oh and my space saver tyre is still the original one with Japanese writting all over it. Never been used.
i found a international student card and a bottle japanese strawberry car spray.. smell quite nice. and some jap money. and whole bunch of lighter
I found a dildo in my glove box, im guessing my car previously had a girl owner....
i took of my driver side door panel and inside.
yes inside my door i found a tooth brush, sealed bandage, cigarette, reseats, bubble gum, a straw, and a $1 coin
all inside my door.
how does so much crap get in there. why the F*** would there be a tooth brush in there any way? :rofl:
only found a flare when my gf kicked it by accident, thenm sorta shit myself incase the f**ker went off in the car lol
havent found anything else yet, the car was detailed before i got it :blush:
I'm hopeing that oneday i'll take the door pannels off and hopefully find something exciting, like a tooth brush lol
My Front Number Plate Holder is SPRING-LOADED...
so that when travelling at speed, the Japanese Number Plate would tuck in underneath to a horizontal position. :bunny:
I don't think it works though on a thin 'Premium Plate'.
Tez
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
