I got 19 x 9.5 on the rear 19 x 8 on the front. 35 fronts, 30 rears. Rides fine I think. If it wasn't for the shitty Sydney roads im sure you wouldnt have a problem driving it anywhere else. It drives no different to when it was on 17s. Youv just gotta tuck your 19s under the guards so it doesnt sit too high. Problem is 265 tyres I cant afford to replace all the time with the big camber you need to squeeze them under...
Yes and everywhere else in the land of oz has crap roads to..lol....19's are for looks only..road ride would be terrible
  • Replies 41
thanks people apreaciate the effort. shitti town and surroundings we got heaps o pot holes so i recon prolly get 18s that r fat sith some thick rubber. then they will be cheaper, legal and look good and be pritty hard to buckle under my circumstances. much apreciated.
ps raise ur car 4 foot pfffft
2 pce 20's are better then the cheapie ones u get.. weight wise no different to stock 17's ride height depends on how good ur tyres are .. compund etc.. but then again i love my extra hard jic coilovers so it didnt matter next up moving to 3 pce 22" work rims when i get some funds together for guard work :)
:laughing-smiley-014:
:laughing-smiley-014: :laughing-smiley-014:
3 pce 22" work rims
:laughing-smiley-014: :laughing-smiley-014: :laughing-smiley-014:
spewin for all the states that go by inches for the increase in wheel size.
In ACT (and i thought that all states were the same) the increase in wheel size is calculated by rolling diameter, +/- 14mm from standard.
so basically the bigger the wheels you get, the smaller profile on the tyres you buy.
18's can be legal on a gemini even though they cam factory with 13's
in qld:
The rim diameter may be varied from the standard size but the overall diameter of the tyre must not vary by more than +15mm or -26mm.
and for width:
The maximum tyre width for a car or car derivative must not be more than 1.3 times the vehicle manufacturer’s widest optional tyre.
However, for an off-road passenger vehicle fitted with front and rear beam axles, the maximum tyre width must not be more than 1.5 times the vehicle manufacturer’s widest optional tyre.
The nominal width of the narrowest tyre fitted to a vehicle must not be less than 70 per cent of the nominal width of the largest tyre fitted and never less than the
vehicle manufacturer’s narrowest optional tyre as indicated on the manufacturer’s tyre placard.
I'm actually considering going for 19's because the R34 seems to have bigger guards to fill out than R33's. I've had some 18x10.5" rims on the rear of my car that came off some unknown vehicle and surprisingly they fit fine and didn't rub, even around Oran Park GP circuit. I think they only had 270 tyres on them though and my car isn't stupidly low.
I just bought 19's for my V35.
RAYS SF Challenge, and are only around 9-10kgs per wheel.
Same as Abo Bob, re the guards. On a V35, even 19's look too small without it lowered.
Personally the correct 19's don't necessarily look Autosalon (not that there's anything wrong with that :yes: ).
Especially on a car with big wheel wells.
Personally the correct 19's don't necessarily look Autosalon (not that there's anything wrong with that :D ).
Agreed, 19s and 20s will not look out of place on a V35 or 350z :P Just as long as they are not cheap chromies :P
hi im interested in getting some big rims for my car but want to know about if there were any problems with them before i go ahead. 18" 19" 20"? do 20" ride really rough and when u hit a pothole buckle? if i got 18s or 19s with like 40 of 45 mm tyres would they be any good?
From my experience, the bigger they are, the easier they bend. and they do. they also ride rougher.
15" are where its at
just got some 19x9.5 (275)rears and 8.5 fronts (235 i think). ride is more bumpy for sure but thats expected with the lower profile tyres. 18s just looked too small on the 33
i thought they would rub but not one sign of rubbing anywhere so im really happy, just need to lower it maybe 1" as its riding at standard ride height still
i just got 20in, 10 inch rears and 9 inch fronts. they look good, but if i could do it all again i would go 18 simply for the practicality. 20 inch is something different but be prepared for guard work if your wanting wide wheels..
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
