  • Replies 682
awsome result dude..
you definately heading out on wednesday? would love to see this run
all the best
Wednesday has been canned due to the weather...Wednesday next week looks the goods now.
What is the weight of the car when you go to the track?
Cheers
the last time we raced it weighed 1474kg...without the 106kg driver...so a 398KW GTR to go 10.3 sec's weighing 1580kg with a synchro box is a fair achievement.
we have stripped some weight out of it since so it will be interesting to put it on the scales at the track next week.
unfortunately i still weigh over 100kg
^Hahaha
What does twoogle mean anyway?
it means nothing...
our number plate reads TWO.06L...meaning two point six litre.
some people when making up custom plates use a 6 as a G
my mate one day was looking at the plate and asked us "what does twoogl mean"?
we had a laugh and explained to him that it meant 2.6litre...and that the 6 was not meant to be a G but actually a 6...
he said nah stuff it im now gonna call it "twoogle"
this name stuck and has grown to even been included in the drag records lists and in magazine articles
its weird how some nicknames evolve and stick
lol time to start running the 1\4 mile instead?
Nice figures anyway, Got any videos of the dyno runs or passes on the strip?
Good luck with Paul - great setup !
I've just got the Cosmo back from getting a few things fixed - so might even go out tomorrow night !
Thanks mate...very keen to look over your creation...well done and very fresh to see somethingout of left field.
Dont be too keen for tomm. night ...its forecast to rain.
we have put off running ours till next wednesday.
wow. thats a very impresive power and torque figure. how does it drive off boost? much loss dow low compared with the old setup?
oh pretty please can you post up a comparison dyno graph of your old setup and this one?
ps. after i find a gearbox (smashed inputrshaft)its valvetrain im doing next. 1.5bar and 8.3k on stock springs isnt probably very smart of me...
post-23582-1188817170_thumb.jpgpost-23582-1188817114_thumb.jpgsorry having a bit of trouble operationg our new HP all-in-one
looks good :yes:
the sweet spot seems to be just on 4500rpm or 130km/h
looks like it comes on like a freight train
hope all is well and the mrs's is well
looks good :yes:
yeah max torque is @ 4500rpm but look at the overall torque spread from 4000-9500 its unbelieveable on the road.
Stace is good and the baby should be here in the next few weeks
Dave a comparison graph will be available next week.
Holy shit. (Says a big single owner)
Paul, you are nuts :P
What gearbox have you got in there?
hehe she's pretty mad (you wont see a torque curve like that with your big single)
ive love to give you a drive steve but that would be unfair to your underwear...lol
its an OS Giken 5 speed.
ill bite haha
not a lot in it here
awesome work...but to be fair...i was just giving steve a little niggle
wait till mines tuned and running some decent boost and then ill go the dyno "pepsi challenge" with ya.
what is your set-up?
main point that was being made in the 1st post was that so many people think to make this sort of power, a big single turbo is the answer...and its just not so. Even low-mount twins can deliver if set-up correctly.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
