I went to the autosalon but i could not wait around all day for the best car at show to run so i missed out on the run.
Looks great and congrats on the win!!! Good to see a RB win a event ;) woulda been different if Miss 2j ran... Anyone know what is up there? =)
Cheer's thanks for the support...
Miss 2j is busted...catestrophic engine failure.
While we did go on the dyno, our car is no dyno queen. We'd be happy to match "miss 2j" up against our beast at the strip...12.2 with her husband driving is far from impressive, and a 1.36 around Wakefield is very poor...Stace runs 11's with only 350kw, and im sure a standard Supra could beat that wakefield time quite easily. A car with a 1000rpm power band does not really "float my boat"....But if thats their thing good luck to them, we rather enjoy what we have built than look at it in a show. Don't get what i have said here the wrong way, as both Jodi and Ross are lovely people, its just a little tiring people comparing our cars all the time. They built theirs to win show trophy's we built ours to race.
The engine build is on par with RH9, JUN, DEVLISH, GTR700 and other monster's that have come out of the CRD garage, the only thing stopping this engine from making big dyno numbers is the size of the turbo(s). Nothing more.
Dave...may take you up on the CDI offer mate.
  • Replies 682
i understand where your comming from and i agree totally. Its just a show car and nothing more. Just a shame that it keeps blowing up..... would cost soooo much money ;)
Keep up the good work the car looked great!
rumour has it the last bottom end was a $30 000 Titan Motorsports item from the states.
ouch!
ouch!
ahh how the hell did they manage to break it then? somethings obviously not right with their combo,,,
i heard the reason why it cost soo much money was because they made her change the management system. the engine only need pistons and a head to fix from the last blow up.
I wonder if we will see this car out on the dyno again.
yeah maybe the compression is too high or the plenum does not flow correctly ;)
more like ...way too much timing caused excessive heat and melted pistons, valves and head.
anyway...this is our thread...not theirs...lol
back on topic
back on topic
if that's the case, and i was them, i'd be finding myself a new tuner
...yes back on topic...almost ready for tomorrow paul??? and when does stace get to pilot it? :sorcerer:
They are up to their third tuner now i believe. Its a definate setup problem.
What power does this 2j make? or did make before it blew?
Cause those times say pretty pathetic, or the driver/s are.
it was around 750 - 800rwkw
Back on topic now - just answered the questions.. no more about this 2j.
It wouldn't be the first time a Supra has run a 12 but I bet it was at eleventy billion mph...
Paul, gimme a buzz on the mobile if you want to run at Supernats.
2rismo, thanks as per phone call...ever thought of being a puppeteer...you certainly know how to pull a few strings.
turbo's HKS GT-RS items
capacity 2600cc
static CR one thing ill be keeping to ourselves (im sure you understand)
What about you promise to tell us when you reach a certain ET? I'm dying to know.
it means nothing...
our number plate reads TWO.06L...meaning two point six litre.
some people when making up custom plates use a 6 as a G
my mate one day was looking at the plate and asked us "what does twoogl mean"?
we had a laugh and explained to him that it meant 2.6litre...and that the 6 was not meant to be a G but actually a 6...
he said nah stuff it im now gonna call it "twoogle"
this name stuck and has grown to even been included in the drag records lists and in magazine articles
its weird how some nicknames evolve and stick
Which is why I wonder why people don't call me Abo Gob...
Looking good Paul. All the best for tomorrow and the rest of the assault.
Thanks Adam, ill give a full rundown of how things went on Thursday.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
