  • Replies 682
The whole map from 500rpm to 7000rpm has been mapped from the little amount of vacume that this engine gets to full throttle.
Power runs is the next step from here to map the rest of the car and clean up.
Should only be a hour dyno work + 15 mins on the street to get it right. I am not in a hurry with this car. If it takes longer then so be it.
how much vaccum at idleand how much vaccum at cruising at say 100kmh?
its a bullseye power S372R. (borg warner/shwitzer)
Holy crap thats a big turbo... :)
The last time I saw one that big was on ESP's Supra and it made 961rwkw (1,287rwhp).
What sort of peak power figure are you predicting?
its not as big as it looks...rated at 900hp. Its still big enough to chirp 2nd though.
Edited by DiRTgarage
its not as big as it looks...rated at 950hp. Its still big enough to chirp 2nd though.
Enough to "chirp 2nd" LOL :)
The one on the ESP Supra is off an 18L Cummins truck engine, its obviously been modified, but Daniel is pretty protective of what exactly he has had done to it.
I'll be happy with my new GT30/76R for a while (mini Twoogle) :).
i cannot remember exactly.. but it idles at 100kpa and it cruises at 100ks a hour at probly 60 70kpa??
will check again on weekend
100kpa absolute, your not kidding there is no vacuum
yeah she's certainly no Dyson Cyclonic.
You should try driving it without hardly any vacuum assist for the brakes...its a bit of a handfull to pull up...or should that be legfull?.
No more posts from you untill you bleed the 4wd system so it works.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
