i hope thats racefuel...i strongly recommend not exceeding 24psi on pump.
There is something strangely tantalising about seeing a boost gauge swing up to 1.8+bar in a car running pump gas haha
  • Replies 682
no way! will be changing it over when i am all setup on friday morning :D
is there a BP near Eastern Creek?
Dont know of any BP's close to Eastern creek. Got the Shell just up the road. If you wanna travel a bit you can go to the united petroleum on Sunnyholt rd. They got 100 octane available
awwwww. you failed to mension your balls up last night... did you have to shart? like when they get hit and you get the cramps and shartings?
well you know that lovely feeling when your seeds cop one...the one that travels up your groin towards your hip...i had that for 3 days solid...morphine tablets were my best friend. All good now...im only on 3 types of medication now including 6 hourly double doses of Panadine Forte. Im able to properly stand and walk not looking like someone has clouted me in the jewels.
What'd they say about driving while putting away that many pills?
not to drive or operate machinery
its funny they did not mention drinking beer. takes another sip of cold Coopers
one of the pills says not to go out in direct sunlight...oww that must be doing some crazy sh1t to me.
Edited by DiRTgarage
no excuses paul i had my leg stitched up the day before powercruise nurse said go home & rest but i put the car back together dyno then powercruise next morning
but if not will keep an eye out for it @ compak attack, good luck
Edited by jas/slo32
it wasn't your 3rd leg though!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
