hay all just want to know how many of u would buy a vented bonnet for your stagea
they are transport approved in queensland make from firbeglass and will help they stagea get ride of a lot of heat
from under the bonnet price i will let u know soon going to the bodykit place today to give them a move on making mine
i will post a pic asap thanks guys and girls :blink:
https://www.sau.com.au/forums/topic/183899-stagea-bonnets-vented/
hmm .. interesting! I wouldnt get one personally just because the stagea is stock as a rock at the moment and more than likely going to stay that way.. and I have never had an overheating problem yet( granted its in the middle of winter )
but back to my point.. it will be interesting to see how these bonnets match the lines of the car ( I noticed on our S2 there is an area near where the bonnet is hinged that it meets with the lines on the rest of the car - sheesh.. reading that again makes NO sense.. least I know what I mean :blink:
oh and I am pretty sure they are defectable in W.A but dont quote me on it.
hmm i would suggest to do a Carbon Fiber ones no point in doing fiberglass. Venting it doesnt matter as long as it looks good. Probably with a ari scoop for the air intake? I would be interested in a CF ONLY.
A matter of interest as well. Probably have your guy to qoute us on the pricing for Fiberglass, wet Carbon Fiber and a dry carbon on a design that we agree om. I can upload the picture for that shows the air scoop if need.
Dale - I agree on the rearward facing vent comment.. but I was thinking more the material ( carbon fibre /. fibergass ) aspect that might be defectable.
Only if the vents face rearward. (engine / coolant system failure could project fluids etc onto the screen apparently)
I don't think so, I may be wrong (I am pretty sure that happened once) but due to the A9X Torana, and even the new turbo diesel puegot has fibreglass bonnet vents so they do comply with adr's I just think that you would have to be careful not to cut any braces or anything to install them.
I think its a great idea myself and I was looking at the same thing myself, anything that removes under bonnet heat can only be a good thing IMO
hay guys went and seen the bodykit guy today he will be starting in a few weeks. carbon fibre is illegal. with these bonnets u will get
a written letter that u can show the cops and u will not get fined for it they will all have id numbers on them and transport will be notified that u have an arftermarket vented bonnet when
u buy them.
will get a pic asap thanks guys
CF bonnet is illegal? hmm i dont know. Cos theres alot of people using CF bonnet and vented too. Im only interested in CF for a seiries 1.
Unfortunately, Yudi, the fact that there are quite a few people using them doesn't make them any more legal...
I would love one, but don't (and probably won't) have the funds to dedicate to this any time soon. Need to do a few other more important things to the car for now, then I'll focus on some minor cosmetic stuff.
the carbon bonnets are "illegal" as they do not provide any crumple zone support in victoria at least so i would assume that fibreglass would be the same?
just my 2 cents
I think there is some confusion in this thread over the fact that ( from what I understand) these bonnets are going to be almost entirely CF or Fiberglass. Its not a steel bonnet with a fiberglass/CF scoop or vent.
Yea I was under the same impression as oxford1327 in regards to the crumple zone etc.
I think its best that each purchaser check with their local authorities about the legalities of it
just my 2 cents
If you smack a pedestrian with one you'll litter their body with Carbon shards and they don't show up on X-Rays.
Or so i'm told.
Edited by Xmetal
hi all
these bonnets are transport approved in queensland they are all made of fiberglass and i will speak to they today about how it works in other states will post a pic today
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
