Can anyone tell me if you have to remove the whole rear member in order to change the 2 bushes that the diff attaches to (which is part of the rear member)??  My bushes are totally shot and I'm thinking is an easy task to remove just the diff or a headache to remove the whole rear member.  Any advice/help would be much appreciated.
https://www.sau.com.au/forums/topic/184097-r32-gtr-diff-bushes/
Believe me, when you change the diff bushes you will notice a complete lack of axle hop. Call Unique Auto Sport, they get them made up or imported. Think I saw one of the traders advertising them also. I only changed the front ones but car is quieter and no more clicking when I take off.
Uniqueautosports do em mine arrived today advertised as noltek (spelling?) but when they arrived they were some brand I had never heard of look okay though !!!!
Come as a kit with the two on the rear subframe and two either side of the front (nose) of the diff
Yeah I got these from UAS this week as well about $90. Both front and rear bushes, with new crush tubes for the front. Front looks easy to change but rears look like a disaster to do with the subframe in the car - I might give them a miss
They are from the states, made for 300zx but the diff and subframe are the same.
Noltec have a part number listed but they didn't have any.
When i did my pinion bushes (Front of diff) i got the noltec ones from WA suspension. Believe it or not they had them in stock. If your still chasing some give them a call they may still have some.
W.A Suspensions
34 Howe St
Osborne Park WA 6017
Ph. 08 9244 2211
Fax. 08 9446 7765
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
