  • Replies 132
Posted Images
wow now you have me thinking lol
Just wondering what other modifications you have done?
Aftermarket plenum being the obvious one, and probably a z32, bigger injectors etc
Is the engine standard internally? How much boost to make 252rwkw and when does it hit full boost?
What size exhaust housing are you using on the 3540?
Thanks,
Abu
Edited by abu
Mods list:
Apexi power fc
Apexi avc-r
Apexi intake pod (mounted in fron bar)..... shithouse in the wet - great in the dry
Custom inlet plenum with belmouthed runners
Custom mandrel bent 3" S/S exhaust
Custom s/s highmount exhaust manifold
Custom s/s dump pipe with bellows for heat expansion
Garrett 3540 turbo .7 a/r and .63 exhaust
Gen111 5.7ltr fuel pump
Gtr fmic
Series 5 550 cc injectors
Tial 38mm external gate
Z32 afm
Q45 90mm infinity throttlebody
and 1.2 bar
hope this helps matie!!!
Edited by mad032
The 3540 for under 300rwkw is a massive overkill. Not only do you sacrifice spool but you sacrifice response which greatly affects low gear acceleration.
When does it kick you in the arse? 5500rpm?
Does it kick you in the arse in the lower gears (1st and 2nd) if rolling on the throttle or does it take until 3rd gear to really get up and go?
That is technically impossible. First and second will ALWAYS make boost later than the higher slower reving 3rd and 4th gears.
Especially with a turbo of such size on the 2ltr; unless you hold your foot on the brake. :P
Regardless I was talking about where it kicks you in the arse; i.e picks up/clears its throat/feels lively/free and screams off.
At 4500rpm its only making ~105rwkw; 5000rpm ~140rwkw and then 5500rpm ~190; the biggest jump in power is from 5000rpm to 5500rpm which suggests a little before 5500rpm is where it picks up and goes.
If it is making all its boost at 4500rpm its not doing a lot with it. :P
hey guys ive got a rb20 fairly stock standard would you guys recommend a GT3071r and what would the response be like ona standard cam. Obviously thingslike exhaust manifold, Injectors ,fuel pump ecu would all be done! thanks guys
  • 1 month later...
those asking about the gt2510 here are some results from my old setup bare in mind i suspect the dyno used was about 5-10kw too generous.
http://www.skylinesaustralia.com/forums/in...t&p=2184825
personally i wasnt a fan of the 2510 as it runs out of puff up top. since then i had it rebuilt into what resembles a GT2530 using a larger garrett turbine and the difference was amazing. it felt it was easily good for a REAL 225+rwkw @ 1.35bar. never had it dynoed due to tuning and workmanship issues but a huge increase nevertheless, it still lacked a lil grunt right up top....to this day even with a grinder spec turbine wheel it still spins the 18" 255 rubber @1.1bar in the dry.
personally i think chasing power under 4500rpm in a rb20 is a waste of time and money. they love to rev and are more efficient making top end power so you just need to make sure you have a good clutch and use it accordingly.
currently im thinking of rebuilding the GT2510 again with fresh bearings and using the GT2871 turbine with ext gate to get a constant 22psi out of it but i dunno how a rebuilt unit would hold up with that kind of pressure daily.....or another idea im throwing around is a GT30 of some sort to get a lil more power up top.
I wouldnt say wasting time and money, but i do tend to agree that sizing your turbo to be on and hiking under 4,000rpm is difficult and often only get a handful of kws at those sorts of revs between a smaller turbo and one that will make 30-40rwkws more over 5,500rpm
I recently bought a Garrett T3G (apparently an old'er version of the HKS 2530), its currently making 188RWKW without a tune on around 15psi, on my quite standard RB20 its making full boost (15psi) by 3200rpm in 3rd gear.
I purchased the turbo for $1000 and its almost a bolt on affair (oil line mods and turbo outlet).
Just another option for the RB20 :P
Can you get Sam to overlay the graph against your GT-RS and the TD06?
will do. ATM Sam's back is stuffed so he ain't working for a while.
what i can compare to is my GTRS and going from the dyno sheet the 2510 produces exactly 50rwkw more at 90kmh in 4th and 40rwkw more at 100kmh. But from 135kmh the GTRS pulls away & the graph doesn't fall off as quickly due to the bigger exhaust housing having less restriction....
I'm gonna get cam gears for the 2510 so hopefully i'll gain at least 15rwkw right up top & the power won't fall away as quickly...but cam gears are only gonna happen once you make that cooler piping for me :)
50rwkws at 90km/h! LOL, OK then, i take back what i have said earlier as most smaller turbos only seem to make 5-15rwkws more earlier in the rev range....i will take the 50rwkws at 90km/h and happily trade it for a bit of top end. My housemates STI with onkly 200rwkws is so much quicker around town then my car because it so grunty at any rev
    • Hey crew, Failed my WOF cause of a lower control arm, and I've decided to hit both arms, and also the compression rods at the same time(seems they're gonna be the most likely upcoming failure points from some discussions with the lads over on the G35 reddit). I've looking at these form Z1:  https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-compression-rod-p-40716.html https://www.z1motorsports.com/front-suspension/hayaku-automotive/hayaku-g35-front-lower-control-arm-p-40674.html I asked Z1 if they'd work as it's the same platform, just RHD vs LHD. I basically got told "Lol dunno". Specifically they aren't aware of any difference but can't guarantee fitment as they haven't done it on a 350GT. So guess I'm asking is if there is any issues with using 2005 G35 coupe suspension parts on a 2005 350GT coupe? Orginally I thought it could be something in the way of the arms that each control arm is designed to be positioned around, but that'd be an engineering nightmare for Nissan needing two different shaped control arms 😅
    • ^ This. The mode door actuator is a common failure, as is the actuator and/or the actual valve for the coolant flow control valve. I also don't know how available the mode door actuator is these days. I've been meaning to look into it and get one from wherever is possible, to keep in the shed for the rainy day when mine eventually fails. Anyway, the advice to you is to search the usual NOS part supply places, or even just go to Nissan and see what they list.
    • Have you got a pic of the actuator? My guess is that unit has failed internally and was flopping around, so the previous engineer who owned it forced it to be fully open to cold air (blocking the heater core path). As far as you can tell, is anything else wrong in the system? Likely you just need a new actuator (not sure how available they are) and then "installation is the reverse of disassembly"
    • I'm happy with the Lsailt unit that I put in, it puts full Android on the top screen so you can run whatever Nav and other Apps you want, while still existing inside the factory functionality like automatic reverse cams, audio input switching, retains factory bluetooth etc. Not cheap and the install was moderate (not simple, not hard) Yours is a V36 not V37 though right?
    • Yeap, all the NC's that I originally looked at that had a hard top were PRHT, which makes the roof line look horrible, hence why I said nope to them My only caveat for another MX5 was it needed to have a hard top, and initially I didn't think you could get a detachable hard top for the NC,  like my NB had Again, a big thanks to Matty for helping me source the detachable hard top for my little girl, they are as rare as hens teeth in Australia, and the few people who have them, keep them Also to Greg, for initially pointing me in the NC direction NC PRHT 🤢🤮 Not mine (I really should take more photos of my car), but a NC with the detachable hard top 😁 To me, the difference in how the detachable hard top roof line looks, and how it actually follows the bodies lines, like they do on NA's and NB's, is chalk and cheese compared to the bulbous looking PRHT
