I have no aftermarket ECU management in my R33. I'm running 11-12psi on a stock turbo and the air/fuel mixture runs rich at these levels because the computer isn't programmed for these levels. I was told i need ECU mods (like fuel cut defender) but i wanted something with more adjustablity without going all-out on an expensive Power FC. I want something that will be good for a future mod plan up to 220rwkW.
Any suggestions???
https://www.sau.com.au/forums/topic/184965-ecu-upgrade/
  • Replies 47
Did a search, SAFCII and Greddy E-Manage look very good, and similar.
Do either have any advantages over the other?
So i can do this piggyback tune to take my stock turbo up to 1 BAR and pump the correct amount of fuel in. That's how it works right?
https://www.sau.com.au/forums/topic/184965-ecu-upgrade/#findComment-3348646
emanage with the injector and ignition harness is far better than te safc. but you do need the support tool or E01 to reap the benifits. SAFCII can be tunned from the unit but is only a afm signal bender. emanage does afm signal bending, injector duty cycle and ignition timing.
SAFCII is about 8 wires
emanage is about 30 wires (with all harnesses)
SAFCII can be picked up for about half the price of an emanage with all harnesses and support tool.
basicly the emanage is the next step up from a SAFCII
https://www.sau.com.au/forums/topic/184965-ecu-upgrade/#findComment-3348706
Not sure what the harnesses are for the e-manage. But it sounds like a better long-term alternative.
What if i want two boost/power setting, like at 9psi for everyday, then flick a switch and jump to a 12psi remap???
Will the SAFCII & e-manage handle this? Cause i have a man. boost controller...will i need some kind of EBC upgrade, or an piggyback ECU & EBC all-in-one unit??? And can i reset the max. factory speed limit with a piggyback???
Edited by R338OY
https://www.sau.com.au/forums/topic/184965-ecu-upgrade/#findComment-3349627
SAFCII can have two maps. just have to swap them over in the settings.
emanage you will have to have two maps saved on a laptop and plug the cable in a load the new one on to swap it over. (not a quick way)
manual boost controller will be ok, you'll just have to wind it up and check your gauges. EBC could be easier if you don't have to start mucking around with the gain settings and stuff.
i don't know that you can get a piggyback and EBC all in one. you can buy the greddy profec E01 (i think thats what its called) and use it with the emanage blue
and no, you cand remove factory speed cut with the SAFCII or emanage.
without getting the additional injector and ignition wiring harnesses for the emanage you might as well get the safcII.
also and most importantly make sure you know someone that can tune them.
https://www.sau.com.au/forums/topic/184965-ecu-upgrade/#findComment-3350279
Maybe with all the messing around it mite be better just to fork out $1000+ for an FC...
I don't know much about em, but far as i know it replaces the stock ECU and it can control EVERYTHING the car does.
Do they stuff up? Should i go a 2nd hand one???
https://www.sau.com.au/forums/topic/184965-ecu-upgrade/#findComment-3351089
if all your worried about is running rich im pretty sure i know how to fix it
ps how do you know its running rich
https://www.sau.com.au/forums/topic/184965-ecu-upgrade/#findComment-3351100
I am selling my WOLF3d plug and play unit for a RB20/25.
Will plug straight into your loom, and can be tuned via hand controller.
Very similar to a PFC except it doesn't use a air flow meter, uses a MAP sensor.
Let me know if your keen, I will do you a good price. Cheaper than any PFC you will find for sale anyways.
Abu
https://www.sau.com.au/forums/topic/184965-ecu-upgrade/#findComment-3351152
re-map :dry:
dude, whateva u do dont go for a power fc. that technology is old and outdated.
if u go the emanage ultimate, it can be continously updated, has more features than the pfc, and it looks like it is the new PFC.
the fact is the pfc is getting older and more expensive.=go the EMU
https://www.sau.com.au/forums/topic/184965-ecu-upgrade/#findComment-3358878
Hi ,
Read this page http://www.skylinesaustralia.com/forums/in...howtopic=154016
I personally think youd have to be mad to buy a pfc for $1500 when you could have the ultimate for less that $900.
I believe the ultimate will eliminate your 180 kph limit, and has the option for a switch between 2 maps, ie race and street.
im about to get mine installed, so if u can wait a week or so ill post up some results then.
https://www.sau.com.au/forums/topic/184965-ecu-upgrade/#findComment-3359029
Hi ,
So about $900 new for the ultimate, and how much for installation and tune?
Thanks,
Abu
https://www.sau.com.au/forums/topic/184965-ecu-upgrade/#findComment-3359033
Thanks,
Abu
I suppose that will determined by the workshop doing the install and tune. for the r33 being a plug and play, i cant see it costing more that $500 all up.
However this is only a guess.
I am getting my ultimate hard wired into my 34gtt (take longer than plug and play) and tuned,
plus tomei pump installed, plus injectors installed, fuel reg and z32 afm for around $1100.
Edited by silverr34gtt
https://www.sau.com.au/forums/topic/184965-ecu-upgrade/#findComment-3359055
Oh yep fair enough.
Plug and play units seemed to still cost around the $500 mark for initial tune and installation (plugging it in..).
As far as I know they don't come programmed with a base map hey, so the tuner has to practically start from scratch?
Thanks for the info, I will do some research.
Edited by abu
https://www.sau.com.au/forums/topic/184965-ecu-upgrade/#findComment-3359067
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
    • no one recommending speedtek gearsets?   i'm in the same boat as Cosline but rwd, I am holding boost back in third to 600nm at the hubs to save the gear as i make nearly 750nm at the hubs on a mainline
