Hey all,
After having an intermittent oil burning and low comp problem, today i pulled apart my engine.
I found an unacceptable amount of piston slap on all cylinders...
Number 6 top ring came out in about 3 pieces. This would explain my intermittent comp.
Number one ring was split in half.
All of the rings looked like this, the rest intact apart from 1 and 6:
Cross section:
All intake components are spotless, free of dirt etc, cooler was cleaned when engine was built. HKS pods.
When the car was tuned, the tuner advised me that the knock sensors werent working, as they heard knocking during tuning and had to take boost out, it didnt read knocking on the pfc, but the tune was fine.
All ring lands are not broken, acl pistons and acl steel rings.
What causes this to happen to the rings?
https://www.sau.com.au/forums/topic/185425-so-i-pulled-my-26-apart-today/
well mate im no engine builder or tuner but if your knock sensors wernt working how could they tell if its wasnt nocking any more after they turned the boost down just cos u cant hear it dnt mean it aint knocking, and also maby the machine work was not accurate enough maby the piston to bore clearance was to big ect
why did you proceed without working knock sensors dude? thats like guarantee'd rebuild.... :(
I did not proceed with the tune, the tuner did and told me after when i picked it up.
So detonation causes this problem?
Minor detonation over a period of time has pounded the shit out of the rings and worn them out like the pic?
well id say its all a tuning issue. were the pistons at all pitted? with the good pistons/rings.. install them and check the ring gaps. (top and second)
Nar no pitting.
Check the ring gaps of the worn out rings?
why did you proceed without working knock sensors dude? thats like guarantee'd rebuild.... :)
Not really, if you have the correct det listening equipment they are not needed.... think Haltech, Microtech etc
It is way to often i see the PFC knock meter used to tune cars, it is an indicator.
all decent tuners will be using something like this http://www.skylinesaustralia.com/forums/in...howtopic=176922 those who arent are winging it.
The guys are right, a tunner who does power FC's and relys on the knock sensors should not be tunning an engine full stop.
Give them a real ecu like a haltech, autronic motec etc and see em freak trying to figure out what real detonation is.
On aside not the cross sectional area of an ACL ring (actualy made by mahle) is that exact shape from new.
If the rings are cleanly broken its more than possible they have been like this since installation and its the builder fault not the tunner. "most" engine issues wont smash rings before they do damage to the lands. You issue sounds very much like an assemble problem.
But if they dont rely on the knock sensors how do they know if there is detonation or not? yes by use of the standalone knock sensor equipment but why mention the knock sensors werent working?
The rings are blue around the inner edge, as if they have gotten freakin hot, and the outer edges are very sharp. I really dont think they are meant to be like that.
Is there any sort of testing of the rings to find out what has caused this?
Could there be anything else that may also have done this to the rings?
Not for anything but this engine has already cost me thousands from the first build, and more thousands are being spent - again. I just cant have this happening again.
Ive spoken to a few people and another possibility was dirt entering the engine, but from where? All manifolds etc are spotless, as is the cooler, the engine has never been run without filters...
installation errors
Oh and from memory the rings that ACL use with their RB26 pistons are meant to be solid rectangular 1st ring and stepped 2nd ring so its possible you rings were put in arse about as well. (yes it does matter)
Those stepped rings are a very brittle matterial and easy to break when installing too.
Edited by Risking
installation errors
Im 90 percent sure the 2nd rings were stepped as well liek theyre sposed to be, but ill double check tomorrow, havent got the pistons here.
you still need to get a feeler guage and chech the ring end gap.
as brad said. it aint screwd together right.
and on the tuning thing. torque production is an indication of timing. you increase it till it stops making torque. it wont ping for a a while yet. but thats how timing is usually done, pump in timing till no more torque is produced. theres no point adding timing if it stops producing a posative increase in torque.
But will the reading be valid? Both top and second rings are worn, obviously more so the top rings.
and if the rings have worn on the outside then ill have a wayy bigger end gap.
Ill measure them tomorrow anyway, ill see if i can measure whats left of the top rings in terms of the step in the pic above.
Hey all,
Number 6 top ring came out in about 3 pieces, some of the ring was missing too. This would explain my intermittent comp, would have been pieces of ring under my valves...
Cross section:
You say you have unacceptable amount of piston slap , like how nuch clearence? What was the clearence ( piston to bore) when it was built? Was the ring gap meassured in the bore ? if yes what was the gap? Are the bores worn now? Can you still see the crosshatch hone ? How was th engine run in?
My guess is that the piston rings were broken in assebly or maybe you didn't have enough gap and they broke when they got hot and expended. I can't realy say without knowing the answers to the above . Don't forget when using forgies you have to have bigger piston to bore clearence than cast pistons .
like dave said measure the gaps on the ones that AREN'T broken. obviously you can't measure the end gaps on the ones that are failed, but measuring the others should give you an idea as to whether or not it's an assembly problem.
Since he says that there is piston slap, I would take it that the (forged) piston to bore clearance was taken into account. However, it may not have been down according to the specific piston manufacturer's specs. I had a previous engine have that much piston slap that I could physically move and see the pistons left and right in the bore. Next rebuild was much tighter and engine was perfect.
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
