So here it is, on the road, bringing me back into the SAU team....
I feel special, i now own 2 r33's.... one good, one bad, ver ver ver bad.....
anyways, let me know what you think... i have had soooo many people ask if its a GTR, so if someone can help me get a GTR front bar, i would love you long time....
https://www.sau.com.au/forums/topic/185462-my-new-car/
lol, thanks boys.... Sewid - i really just wanna be your car??? I will call him GTS25tR
its kinda even more confusing sitting behind it in traffic, especially with 265's on the back - very very wide tyres!!!!
https://www.sau.com.au/forums/topic/185462-my-new-car/#findComment-3355746
i never understood door open shots.
the door open shot requires active participation on your part. you need to visualise the car flapping it's doors and taking off... flying like a bird.
https://www.sau.com.au/forums/topic/185462-my-new-car/#findComment-3356247
wtf lol
Looks like a nice clear car man, but have to say take the wing off and slam it.
Will look heaps better.
Just needs a nice big cooler.
https://www.sau.com.au/forums/topic/185462-my-new-car/#findComment-3356257
Haha how can you mistake it for a GTR..
wtf lol
Nah Put some chomies on it and a nice big GT wing and you're set!
Hahaha I just burst out laughing then. Nice one BB
https://www.sau.com.au/forums/topic/185462-my-new-car/#findComment-3356284
Pics of nitrous system?
haha, Nick, i'll PM them to you sometime soon
umm, corinne, what more can i say but....
If you have nothing nice to say (which seams like never ever you do) please keep your words to youself.
https://www.sau.com.au/forums/topic/185462-my-new-car/#findComment-3357724
could have picked another colour.. lol
why copy me for :P
how much did you pay for the car dude? and where did you buy it? whats done to it? mods wise?
Also i spotted your car parked outside near tarenpoint.. like past jaycar..
Edited by siddr20
https://www.sau.com.au/forums/topic/185462-my-new-car/#findComment-3357747
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
