So I have been looking into a RB swap for my S13 and I think I want to go with the R34 Neo but I have a few questions about differences between the Neo and Series 2 engines. When it comes to upgrades or even just OEM parts will the parts for a Series 2 motor work on a Neo? Physically what are the differences? Also what parts should I consider replacing before installing the engine into my S13?
Theres plenty of neo specific head upgrades like poncams and fine tune timing belts ect. the stock rb25 neo has superior torque and power to the earlier rb25 also.
Parts to replace. Might want to look at a set of splitfires, i had problems with standard coilpacks failing. Other than that i cant think of anything, unless u want to go for extra power. :nyaanyaa:
Edited by silverr34gtt
Parts to replace. Might want to look at a set of splitfires, i had problems with standard coilpacks failing. Other than that i cant think of anything, unless u want to go for extra power. :thumbsup:
I have seen a lot of people talking about replacing the water pumps, oil pumps, time belt, timing belt tensioner and idler pulley, etc bc the engine is most likely coming from a junkyard and has been sitting for a while. Do you think it is all necessary precautions?
Water pump, timing belt + idlers, crank + cam seals, various water hoses. From the viewpoint of ensuring absolute reliability in those areas - YES. Oil pump as a service issue though, I doubt it.
Some of the parts aren't particularly cheap, but if you consider the time + labour factor involved once an engine is in the car, it is a smart option while the engine is sitting on the bench/workshop floor.
Both type of Rb25DET engines have same static compression ratio. 9.0:1
Rb25DET Neo has same turbo as series 2 R33 RB25DET, but has the larger (OP6) exhaust turbine housing. Same housing as used on the VG30DET. (Single turbo engine)
Honestlly the Neo motor is going to be younger, so it would be the better option...
However that said some second hand Neo's can be rather expensive compaired to theolder S2 rb25, so I guess you just need to weight it up...
But on the solid lifters alone id be buying a neo motor...
it somes with hks fuel rail bigger injectors, fuel reg and better coil packs. i have a good turbo so prob just a computer and i guess i would be happy for a while. but just wanna no. some people say s2 25 is the best and some say neo. just real confusing. dont wanna get the wrong one hahah
Go for the better, newer Neo if you can afford it.
S2 RB is great engine too, and will be cheaper to buy and probably cheaper to mod (if thats the plan), but it's not as advanced as the R34 Neo.
The Neo is more enviromentally friendly. Guess that's not important on this forum :thumbsup:
    • would a r34 gtr hood line up with gt/gtt stock fenders? after latch, front bumper and hinges are swapped for gtr ones? or would the fenders be too low or high in relation to the hood surface? ( I believe seeing somewhere that gtr front fenders use some type of riser for the sides, but do not know how that relates to stock gt/gtt fenders.)
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
