Oil sits about 110degrees when ur ontrack
about 90 with decent airflow and casual/semi spirted driving on a 25 degree day.. obviously fuctuates during hotter temps.
Water I have no idea..
On the subject i think my r34 coolent/engine temp sensor is crap and the gauage is showing normal all the time when I suspect it is not this way.. Anyone know of a cheap measuring tool to monitor real temps?
Best bet I think, would just be install a water guage, they're handy to have in the car anyhow.
oil temp cruising sits usualy 10-15deg hotter. on the track can get up to 150 if yoyr trying hard
thats really bad because oil breaks down at around the 130 degrees mark... This can cause catastrophic failure
As a comparison, RB25DET in my 180sx which still retains the air con condensor (no room for a clutch fan)
Water Assistance = Nismo thermostat, twin SPAL 12" Thermo's, Koyo 53mm Radiator, Pivot Fan controller
Oil Assistance = Greddy Oil Cooler.
Retain the lower splash/air diversion plastic shielding - it works.
Power FC water temp reading = 75 degrees
Pivot Fan Controller water temp reading = 78 degrees (seperate sensor is within 5cm's of the factory water temp sensor)
Defi Oil temp gauge shows 82 - 85 oil temp.
Also you're in Brisbane like me, so half of the figures from members on this board are significantly different to ours due to the cooler conditions on average.
  • 4 weeks later...
  • 1 month later...
So 80-85 degrees water temp is normal operating engine tamp for RBs, right? I got electrical fans and 2 step switch. 1 step is at 84 degrees. I thought it was too low some how )) Maybe I would get a better mileage with higher water temp ?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
