so hows everyone for a fund raiser, we have about a week to gather a few items, can be anything i think
i'll put together raffle tickets if you want (my gf and i are planning to go out tonight, she has to get ready, so it will give me plenty of time :))
i also have a turbo timer that might be up for winnings :(
so thats my 2 donations, anyone else? i think its a good idea coz i mean $2 - $5 per envelope of about 5 raffle tickets to win things that are donated its all good :( please reply soon
https://www.sau.com.au/forums/topic/18628-mas-dyno-bbq-fundraiser/
  • Replies 181
i wont be dynoing my gfs car seeing as it was dynoed there like a week ago so theres no point... will be up for the BBQ... dont really have anything to offer for the raffle tho... might think of something.
You dont have to be getting your car dynoed to come.
You can just come to watch... and eat sausages. Mpre the merrier. And it looks like there will be a heap of people there!
We are doing this as a fund raiser so doesn't matter if your not gonna go the dyno... more on the dyno the better...
I have a leather Nismo gear shifter to throw in for the raffle prize. Is brand new - still packaged (RRP $160). Will ask around from some other stuff...
I'll get some ticket books - I think you can get them from Officeworks et al.
Originally posted by inark
lol apachex
that avatar still freaks me out a little :)
so we gotata be there early aye... i'll try my bestest.
ahhah its alrite man, its only my dog, she aint that scary! she iz really small too, like 50cm in length, not that tall, one of those small yappy dogz heheeh, just for u ill change it though, so everytime u come on and ive posted u wont be freaked out and stuff
umm yeah maybe i missed it, but wat are the costs involved?
and does it matter who goes? coz yer some of my non-sau friends seem interested eheh
proper details would be handy :)
hahaha nah man u dont have to change it... i just remember when u first joined it freaked em out cause i didnt know what it was... :) then i worked it out after like 3 weeks! lol
its at BMT which is 6 something or rather thingy in fairfield... lol sorry but i have the memory of a... thing that... yeah more details please!! :)
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
